It is currently Sat Jul 26, 2025 12:59 am
 Post subject: HI LO HELP!!!
PostPosted: Sat Apr 05, 2008 5:36 pm
Hi,
i have just installed hi lo's on the back of my car, i have wound them all the way in as i want to lower the car. when its wound all the way in it is the same height as the standard trumpet. have ibought the wrong sort of hi lo or do i need to cut the rods down.
Any help will be appreciated.
Jeff
0414 723 088
[email protected]
PostPosted: Sat Apr 05, 2008 5:59 pm
That sounds really suss. Do you original trumpets look to be cut down or modified at all? And you wound in both nuts on the hi-lo I presume? Got any pictures of the two side by side?
PostPosted: Sat Apr 05, 2008 6:10 pm
with the hi lo and rod in place it is exactly the same length as the trumpet, and the hilo is screwed all the way in. have you got any idea how long the rod should be.
the trumpets are original and have not been modified
thanks
jeff
 Post subject: mm1275
PostPosted: Sat Apr 05, 2008 6:13 pm
Who makes them? Sounds pointless, are u talking about the front? Or both F and R
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Sat Apr 05, 2008 6:14 pm
i have only installed the rear so far. the idea was to lower my mini as it sits too high
PostPosted: Sat Apr 05, 2008 9:18 pm
I had the same thing, you get an old hydro strut or what ever it is... Just cut that down?
Life's a garden.... Dig It!
PostPosted: Sat Apr 05, 2008 9:50 pm
Gordo not sure where your comming from thier..but have you also replaced the Donutes also as new ones will also raise the suspention also. If not make sure the Hilo is sitting in the donute all the way and dont forget it will settle and lower anyway :wink:
PostPosted: Sat Apr 05, 2008 10:50 pm
i used the same donuts and they are sitting in there evenly. i bought the kit through a local mini guy in perth. i think that the rods are too long.
can anyone tell me how long should the rods be???
thanks
jeff
PostPosted: Sun Apr 06, 2008 6:28 am
I vaugely remember someone else having the problem last year
PostPosted: Sun Apr 06, 2008 7:08 am
High heel ninja
From memory i think you have to cut a inch off the hyrdo bars to obtain the right ride high with hi-lo's.
But its been a long time since i fitted a set so don't qoute me.
Doogie
