Rear stub axles for hydro https://www.ausmini.com/forums/viewtopic.php?f=2&t=40796 |
Author: | cd [ Sun Apr 06, 2008 10:10 am ] |
Post subject: | Rear stub axles for hydro |
Hi all After some rear stub axles for hydro trailing arms. The helper spring pins on mine are badly worn. ![]() Would like to get 2x r/h, then all axles are r/h thread. Anyone know where I might be able to source them from? Thanks |
Author: | drmini in aust [ Sun Apr 06, 2008 10:20 am ] |
A much easier solution is remove the arm, then build the worn pin back up with weld. TIG, MIG or oxy will do. ![]() |
Author: | Mick [ Sun Apr 06, 2008 10:41 am ] |
I haven't tried it, but could the old pin also be cut off, a hole drilled in it's place and a new pin pressed in?? This could be easy at home if you don't have a welder..a drill press would be needed however.. |
Author: | drmini in aust [ Sun Apr 06, 2008 12:24 pm ] |
If you don't want to weld it, use the old wet arm to dry suspension conversion trick- cut the `pin' off, drill and tap a 3/8 UNF hole in the back of the stubshaft (it and the `pin' are 1 piece) and screw a Grade 5 or 8 bolt in. ![]() |
Author: | cd [ Sun Apr 06, 2008 2:08 pm ] |
thanks for the replies. But I was also considering putting a r/h one in the left trailing arm, so all axles are then r/h thread. Ive done a disk brake conversion (front) & both front shafts were the same p/no & thread. |
Author: | drmini in aust [ Sun Apr 06, 2008 2:15 pm ] |
The reason the LH rear nut on a Mini or Moke is LH threaded is so that any rotation of the bearing will tend to tighten it. The fronts are a totally different setup- the nut there goes round with the drive flange. Have you buggered the LH thread up or something... ![]() |
Author: | cd [ Sun Apr 06, 2008 5:27 pm ] |
Thanks for your info Drmini I took out the l/h stub axle to repair (weld?) the helper spring pin. In pressing it out, I cant recall if ant damage caused, but I know the circlip retaining the stub shaft has spikey bits (cactus). I will talk to Karcraft tomorrow & see if they have any or Lee Bros Didnt realise the reason for diff on rear l/h axle. Thanks |
Author: | drmini in aust [ Sun Apr 06, 2008 6:36 pm ] |
I think you will find the proper stub axles are NLA now. They haven't made a new Mini anywhere for 8 years... If the corner of the LH thread is damaged, just grind a chamfer on it. ![]() |
