It is currently Sun Jul 20, 2025 10:58 am
 Post subject: window jets
PostPosted: Mon Apr 07, 2008 1:35 pm
does any body know about window washer jets, they are fairly new and i have tried putting water in the bottle, u can hear the pump working but no water is coming out....???
thanks leighton
PostPosted: Mon Apr 07, 2008 1:40 pm
You could try pulling off the hose from the pump and see if the pump is actually pumping water through. If so, re-attach hose and move on the next part to see if there is a blockage (ie. washer jer, T piece or whatever is next in line)
PostPosted: Mon Apr 07, 2008 1:43 pm
AHH yes thats an idea thanks will try cheers leighton
PostPosted: Mon Apr 07, 2008 1:49 pm
If it hasn't been used in a while, is it the sort of pump that needs to be primed? I haven't looked closely at mine, as I haven't had the need for it yet, but your post reminded me of a stupid manual fuel pump I felt the need to hurl obscenities at the other day.
Perhaps using an eyedropper or syringe to force water down the tube until it reaches the pump device may help?
Just a random thought, hope it might be of assistance!
1988 Holden Commodore VL Executive
1988 Holden Commodore VL Executive (Parts Car)
1963 Ford Anglia Deluxe
