It is currently Sat Jul 19, 2025 8:17 am
 Post subject: no brakes
PostPosted: Thu Jan 20, 2005 6:12 pm
just bought a 1977 clubman
Biggest job is the brakes. They don't work at all until right at the end of travel of the pedal even then they are v poor. Handbrake seems to work ok.
Any ideas on where to start solving the problem. Please help I want to drive it
Sean
1977 Clubman
PostPosted: Thu Jan 20, 2005 6:15 pm
Adjust the brakes, read the manual if you have one.
If the pedal doesn't then come up, try bleeding.
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Thu Jan 20, 2005 6:25 pm
Check that the clevis pin has not fallen out, it connects the brake pedal to the master cylinder.
I had a Clubman that was missing the pin and mo matter what you did to the brakes (bleeding, adjustment) the brakes would only work on the very last bit of pedal travel.
PostPosted: Thu Jan 20, 2005 6:29 pm
how do I find the clevis pin
1977 Clubman
PostPosted: Thu Jan 20, 2005 6:41 pm
Check each wheel cylinder to see if they aren't leaky.
If you pump it up, does the pedal come up?
Try bleeding them.
Could be the master cylinder.
PostPosted: Thu Jan 20, 2005 6:45 pm
no the pedaldoes not pump up
1977 Clubman
PostPosted: Thu Jan 20, 2005 7:10 pm
start simple, do the easiest things first - check the fluid, adjust each wheel, bleed them, then start checking the wheel cylinders etc,.
 Post subject: other jobs to do also
PostPosted: Fri Jan 21, 2005 9:45 pm
Thanks for the advice everyone I will start soon as i have fitted a new high/low - any tips for that. Oh yeh lots of welding to do also - new sills bought today so welding and platepatching tips would also be most excellent
1977 Clubman
 Post subject: top of the pedal
PostPosted: Fri Jan 21, 2005 10:34 pm
Up under your drivers side dash.....follow the brake pedal up....it is what conects the pedal to the master cylinder....
There is a whole thread on replacing it!!! search on Clevis.....
PostPosted: Sat Jan 22, 2005 5:57 am
Unless you are 4ft high or a contortionist, I'd pull the drivers seat out first... :wink:
PostPosted: Sat Jan 22, 2005 8:26 am
any girls out there wanna help sean find the clevis?
PostPosted: Sat Jan 22, 2005 11:17 am
Location: thornleigh sydney...round crnr from suzitech!!!!
hahahah!
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
PostPosted: Sat Jan 22, 2005 5:32 pm
i was told since i was a littlun that brakes are an optional extra on a Mini ;)
PostPosted: Sat Jan 22, 2005 5:50 pm
make sure u put the clevis pins on nice and tight coz it is such a pain in the arse to reach under there and put them in every time they fall out!!! :x
Potato
