1275 crankshaft identification- the searches dont confirm! https://www.ausmini.com/forums/viewtopic.php?f=2&t=40873 |
Author: | marcello [ Tue Apr 08, 2008 2:43 pm ] |
Post subject: | 1275 crankshaft identification- the searches dont confirm! |
hey all. i have this 1275 crank that i am not sure what it is. it has AEG???FORGED into the webs of it but the numbers are ground off so i cant make out the three digits that follow it. it also has 12G1288 Stamped over the top of where the above AEG code has been ground away. i know 12g1288 is a small journal 1100s crank but this crank appears to be tuftrided ( i can file the webs as they are very hard) which makes me wonder if it is an s crank? i am wishing to list it on ebay and just want to get my facts correct. thanks. |
Author: | drmini in aust [ Tue Apr 08, 2008 2:47 pm ] |
Yes it's probably an early 1100S one. All the small journal 1100S cranks I've ever checked were tuftrided. They are less likely to crack these days in race motors than the old and now brittle S EN40B ones. To fit it to an S block you would need +.030" thrust washers- these are NLA from UK but are still made here by ACL. I got some from Lindsay Siebler, www.minis.com.au |
Author: | marcello [ Tue Apr 08, 2008 4:25 pm ] |
thanks. i thought this was the case. so its a good crank for high powered motor? is there any negatives to this crank? what would someone expect to pay for one these days? sorry about all the questions |
Author: | drmini in aust [ Tue Apr 08, 2008 4:30 pm ] |
marcello wrote: thanks. i thought this was the case. so its a good crank for high powered motor? is there any negatives to this crank? what would someone expect to pay for one these days? sorry about all the questions
Yes it's a good crank for a high powered motor. Early ones were crossdrilled, the later ones not, but they are both good. Only negative is you can't stroke it like the big journal ones (but they are all soft, so meh). ![]() What it's worth depends on its size- a good std/std one these days would probably bring $350+ from a racer, IMO. Get it crack tested before sale, or sell it subject to testing. ![]() |
Author: | gerg [ Tue Apr 08, 2008 5:53 pm ] |
Marcello, I have an early 1100s cross drilled crank in my motor and GR said they are the ones he prefered in all of his race engines, so yes as Kev said they are great for high power motors. cheers Gerg |
Author: | marcello [ Tue Apr 08, 2008 7:44 pm ] |
thanks guys for the help. i have been thinking about selling it to get a en40 crank but i guess as this one is approved by GR then it may just go into my 1275. good o! |
Author: | drmini in aust [ Tue Apr 08, 2008 7:53 pm ] |
Just remember the tufftriding process doesn't go very deep. If the bearing journals are ground well undersize they will get soft. On an S EN40B crank, the nitriding is deeper- some say .040" or more. It's a mystery how they got the depth they did, as most nitriding these days is only good for .010". It's a lost art apparently. |
Author: | marcello [ Tue Apr 08, 2008 8:10 pm ] |
its standard on the big ends and 10 under under on the mains. it needs a regrind on both though. will it be okay? |
Author: | drmini in aust [ Tue Apr 08, 2008 8:12 pm ] |
marcello wrote: its standard on the big ends and 10 under under on the mains. it needs a regrind on both though. will it be okay?
Sure. ![]() |
Author: | Matt68 [ Wed Apr 09, 2008 9:16 am ] |
drmini in aust wrote: Just remember the tufftriding process doesn't go very deep. If the bearing journals are ground well undersize they will get soft.
On an S EN40B crank, the nitriding is deeper- some say .040" or more. It's a mystery how they got the depth they did, as most nitriding these days is only good for .010". It's a lost art apparently. Hey Doc, Is there any way to tell if the nitriding is still good on an S crank? I have a 1071 S crank freshly ground to 0.020" under on the main journals, was hoping it would still be treated, but how to tell? (sorry for the hijack, I too have heard from trusted mini mechanics and racers the 1100S S/J cranks are one of THE best 1275 cranks, tuftrided, and bloody good in general!) Matt |
Author: | drmini in aust [ Wed Apr 09, 2008 9:23 am ] |
The time to tell if it's still hard is when it's being ground, it is obvious to the dude working the grinding machine. The spark pattern and grinding sound are different. You can't really do a Rockwell etc test on a journal which is going to have bearings running on it there- an exception is maybe the centre of the main journals (if you are using pre-A+ bearings with the groove). There is one place left in Melbourne which does tuftriding- for the aero industry, most of the others in Oz have stopped the process due to environmental and health concerns. No, sorry I don't know the name of the place... try a Google search. ![]() |
