KLAS wrote:
IIRC chrome rings are more resistend to dirt particles, maybe of advantage in dusty locations or if running without airfilter. but they may anneal from the heat of operation and loose radial tension
The same thing happens with plain cast rings.
The 73mm Hypatecs in my 1412 stroker came out of GR's 1360 Elder 8 port dyno day motor- after 4 hours dyno running the cast top rings had lost 1/2 tension, so I got a Nippon ring set from him for my engine build.
Chrome rings are supposed to give reduced bore wear. Only downside is they do take longer to bed in.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
