Rear Wheel Bearing Questions (taper roller)
https://www.ausmini.com/forums/viewtopic.php?f=2&t=41041
Page 1 of 2
Author:  Matt68 [ Mon Apr 14, 2008 1:04 pm ]
Post subject:  Rear Wheel Bearing Questions (taper roller)
Hi Everybody,
I noticed that the rear wheel bearings on the passenger side on Animal were a bit 'sloppy', so pulled the hub off to have a look.
The reason they were sloppy was the nut was loose. Tighten it up a bit and the hub locks solid.
You can tighten it up finger tight and the hub gets very stiff. a tiny bit more with a socket and extension bar (no leverage, either by bar or ratchet) and it is enough to lock it up.
The bearings are all brand new, well greased etc, the outer bearing is a taper roller style. What are the things to check, how to fix etc.
matt
Author:  AEG163job [ Mon Apr 14, 2008 1:16 pm ]
I thought the inner bearing was taper-roller too, and supplied as a matched-set, spacer and all. Maybe you can shim the spacer up to obtain the required pre-load.
Author:  Matt68 [ Mon Apr 14, 2008 1:36 pm ]
This is on the rear, and I guess I don't actually know how they go together at this point, so some basics and a diagram (crayon accepted :wink: ) for me would be great!
Matt
Author:  mattsmadmini [ Mon Apr 14, 2008 1:44 pm ]
Bean, where are you?
Author:  drmini in aust [ Mon Apr 14, 2008 2:00 pm ]
If locking up, either there is no spacer, or else the spacer is the wrong width (too narrow).
This happens with front kits lately, back too probably.
See my tapered roller bearing thread in how-to forum.
Author:  66S [ Mon Apr 14, 2008 2:29 pm ]
Hi,
I had this a while ago on the rears. I added a shim to either side and corrected the problem but I have heard that some folk biff the spacer and treat the hubs like regular wheel bearings. What does Dr Mini think of that idea?
Regards
Al
Author:  drmini in aust [ Mon Apr 14, 2008 3:40 pm ]
66S wrote:
Hi,
Regards
Al
Yes there's nothing wrong with doing that at the back, IMO, the nuts are pinned anyway and it's not a CV assembly that has to be kept tight.
Think of it as like a typical front wheel hub for a RWD car, except the bearings are same inner and outer.
Author:  Matt68 [ Tue Apr 15, 2008 8:57 am ]
Hi Doc,
I read your 'how-to' (Good read, Thanks! :D ) And am still a little confused.
If the spacer is too wide, wouldn't this cause the binding, as the outer bearing becomes 'clamped' in the hub against it's race as the nut is tightened??
And therefore if it too thin, it won't tighten enough and there will be slop?
But youre how to descibes the opposite?
Anyone able to give me a basic guide to how these bits are supposed to work (speak slowly now!)?
matt
Author:  rampage101 [ Tue Apr 15, 2008 1:05 pm ]
No, see with tapered bearings, if the spacer in the middle is too thing, then its going to have to crush the bearings before they seat up against the spacer, so because its tightening it so much its locking the bearings in there carriers. Where as if its too big (the spacer) then the nut will feel like it torque's up correctly, but because the bearings are done up tight with the spacer but not tight enough for the hub, there is your freeplay.
Author:  Matt68 [ Tue Apr 15, 2008 1:18 pm ]
Starting to make sense, I think.
Anyone want to break out those crayons for me?
:roll: :roll:
Matt
Author:  rampage101 [ Tue Apr 15, 2008 1:24 pm ]
See here for some illustrations:
http://en.wikipedia.org/wiki/Tapered_roller_bearing
Or search google images:
Its mainly because of the taper that causes this, because you need teh spacer in the middle so it doesn't try and pull the actual bearing too far into the bearing seat.
Author:  justminis [ Tue Apr 15, 2008 8:30 pm ]
I've used crank shims, the ones used under the timing gear pulley, to set up rear tapered roller bearings. It was locking up as Matt describes, 2 shims did the trick.
Author:  Matt68 [ Wed Apr 16, 2008 10:01 am ]
Thanks Steve, Ken told me the same tip, will be extracting some from the old motor in the shed soon!
matt
Author:  justminis [ Wed Apr 16, 2008 6:42 pm ]
Yep, Ken and I did it on my car at Mini Automotive :D
Author:  simon k [ Fri May 01, 2009 10:40 pm ]
woo hoo - search worked!
I had the same problem, pinched a pair of crank shims off my spare motor's crank, fixed!
