smelly wrote:
Has any one orderd straight cut gears from the UK ?
And can any one tell me if all the gears in a rod change box are the same as remote 22g1128 gear box.
Also is there any other little part i will need to order at the same time to change to straight cut gears?
We got a set of ST straight cuts from Minispares years ago,
kit number for 22G1128 remote box is C-AJJ4014.
Kit number for early rodchange box is C-STN76
The reverse gear is different, I think that is all between them.
These numbers are from my Minispares catalog.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
