Boot Hinge Bolts https://www.ausmini.com/forums/viewtopic.php?f=2&t=41225 |
Author: | lilmatti_69 [ Sat Apr 19, 2008 4:03 pm ] |
Post subject: | Boot Hinge Bolts |
Hey i was just wondering what bolts are needed for the boot hinges for clubmans, i need the bolts that hold the actual boot to the hinge, not the hinge to the body. I also need the bolt or nut sizes for the door hinges. Cheers |
Author: | Mick [ Sat Apr 19, 2008 4:22 pm ] |
The boot hinges use studs to bolt onto the bootlid. they can be replaced (if the studs are missing) with standard (and very short) 1/4 UNF bolts. same goes for the door hinges, except on the doors they use a shaped washer to stop allow the nuts to pull up flat without distorting the door skins. |
