It is currently Mon Jul 28, 2025 9:07 am
 Post subject: NSW wheel laws.
PostPosted: Sun Apr 20, 2008 4:20 pm
Ok. Sp i'm back on the track of desperately want to drive the mini around, and so have to get it registered. (I'm sure you all know how it goes)
My question is, with the 13" x 7' wheels, because they are more than 26mm bigger than the original 10", they do protrude. If I got bigger flares to cover the wheels do you think it would still pass rego?
The oil leaks, although need fixing, can be "fixed"... :roll:
The only other problem with the car is that the battery is not recharging, and now it won't start. Makka thinks its corrosion somewhere. Is this something I can get dad to help me fix?
Thanks
Cass
Talk is Cheap because Supply Exceeds Demand
mattsmadmini wrote:
you've got awesome norbles
PostPosted: Sun Apr 20, 2008 4:29 pm
As for the not starting bit, check the battery connections in the boot. Twist the battery terminal to see if it on tight. Then check the voltage there at the posts or see if the battery will charge from here.
Then check it again under the bonnet.
Depending on a thousand other factors, it might be the battery terminals, it might be other things...but one thing a at a time...
PostPosted: Sun Apr 20, 2008 6:08 pm
I is a mookenik
you might juz need a new battery cass if its not charging. is the alternator charging it once its started?
as for rego. if you put big flares to cover the wheels you will pass rego. the wheels cant pretude past the guards but with flares its an exception.
and the oil leak i told you before juz give the engine a wash so you get the rego and fix it later.
PostPosted: Sun Apr 20, 2008 7:13 pm
tinymorris1969 wrote:
you might just need a new battery cass if its not charging. is the alternator charging it once its started?
and the oil leak i told you before just give the engine a wash so you get the rego and fix it later.
My brother just put a new battery in it. it will be a contact problem somewhere I think.
PostPosted: Sun Apr 20, 2008 7:38 pm
check the fluid levels in the battery, also you alternator might be shot?
PostPosted: Sun Apr 20, 2008 10:48 pm
not charging.. loose fan belt slipping and not runing alternater proply? or maybe not.. :?:
Davids Automotive Detailing: 0467 629 947
Professional Buff & Polish- Scratch, swirl removel
https://www.facebook.com/pages/Davids-A ... n=timeline
PostPosted: Sun Apr 20, 2008 10:53 pm
I is a mookenik
hang a tick. cass when you say not charging are you meaning its not being charged or its not holding a charge??? now if its a new battery check alternator, alternator belt then go through and check your wiring.
if you got a multimetre test to see how many volts the alternators putting out to the battery. if its not enough check the belt
PostPosted: Sun Apr 20, 2008 11:40 pm
Not charging. Ignition light stays on after car has started (not that there's enough charge to even turn the engine over at the moment)
I think it will either be an issue of not charging, or the charge not getting through to the starter motor.
PostPosted: Mon Apr 21, 2008 7:11 pm
I is a mookenik
ok if that light stays on its the alternator. tiny does it till you rev him to 2000rpm then it goes out but if its stay on continously then alternator isnt charging or your belt is really loose.
PostPosted: Mon Apr 21, 2008 7:12 pm
If the light stays on to 2000 rpm then goes out, either the belt is slipping or the alternator needs new brushes.
It should go out well before 1000 rpm.
PostPosted: Mon Apr 21, 2008 7:18 pm
I is a mookenik
yeah i know doc but the belts been tightened and the alternators been recod twice and still same problem. :roll: doesnt matter still charges the battery
Users browsing this forum: winabbey and 80 guests
