It is currently Sat Aug 02, 2025 10:05 am
 Post subject: mini moke export tank??
PostPosted: Sat Apr 19, 2008 8:02 pm
i was wondering how hard it is to get hold of a mini moke export tank??
how do you conect it up to van for a second tank???
cheers damian
PostPosted: Sat Apr 19, 2008 9:01 pm
Very hard to get hold of!
I had one, intended as a second tank for my Moke. I sold it a few months back on the Moke forum. It went very quickly.
Apparently it's the same as an Austin-Healey Sprite, so you may have more luck finding one that way.
As to fitting to a van, I don't know of anyone who has actually done it yet, but it looks easy enough.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sun Apr 20, 2008 8:49 am
As an alternative to the export Moke/Austin Health Sprite tank, a Morris Minor/1000 fuel tank could be used.
I fitted a Minor tank to an export Moke in the mid 80's as the original tank was rotten. Length wise Minor tank is good, but a little narrower. A strip from the tank to the body was all that was required to mount. Had to also muck about with the fuel filler as it is on the opposite side. A bit of exhaust pipe bent up did the trick. This shouldn't be a problem if intended as second tank for a van.
Steve
PostPosted: Sun Apr 20, 2008 10:26 pm
Lucky - theres one on ebay at the moment, $231 with 5 days to finish, could get really expensive.
http://cgi.ebay.com.au/Mini-Moke-EXPORT ... dZViewItem
