It is currently Tue Aug 05, 2025 7:17 pm
 Post subject: number question
PostPosted: Wed Apr 23, 2008 6:53 pm
I is a mookenik
ive asked this question to a few people and they cant tell me what it is. i thought it might be a number from production.
the number is 1015/6756 and engraved on the block where the little flat bit is above the alternator. some people say its juz an engine number some people say its an overbore number. just was wondering if anyone on here would know.
 Post subject: Re: number question
PostPosted: Wed Apr 23, 2008 7:07 pm
the number is 1015/6756 and engraved on the block where the little flat bit is above the alternator. some people say its just an engine number some people say its an overbore number. just was wondering if anyone on here would know.
That is the engine number. It is an Australian made engine.
The 10 means it is a 1098cc engine.
The 15 means it is the 15th variation which basically means it is a very late 1100, probably out of a Leyland Mini from about 74/75.
The 6756 means it is number 6756th off the line.
PostPosted: Wed Apr 23, 2008 7:10 pm
I is a mookenik
ah ok cool. i dont know why someone i asked thought it was a number someone put on when they overbored the motor..
PostPosted: Wed Apr 23, 2008 7:15 pm
Does the number match your rego papers? (I hope so!) :D
Just make sure that if you ever get the block decked that they don't grind off the numbers. :wink:
PostPosted: Wed Apr 23, 2008 7:20 pm
I is a mookenik
yeah ill make sure and ill double check it lol i had a feeling the motor was out of a clubby
PostPosted: Wed Apr 23, 2008 7:28 pm
Not a Clubbie. :wink:
A Clubman has 1000 to 1004 prefix. (maybe even a 1007)
It is a Leyland Mini number.
PostPosted: Wed Apr 23, 2008 7:30 pm
I is a mookenik
so your saying its not even a mini engine :shock:
PostPosted: Wed Apr 23, 2008 7:31 pm
Is it engraved or stamped Joe , they were stamped originally and if it's been done by hand with an engraver it may cause problems with a rego inspection .
The term Clubman was only officially used until ~1973.
After thet they were all called Leyland Mini. :lol:
PostPosted: Wed Apr 23, 2008 8:27 pm
I is a mookenik
ah ok well it looks like an engraving but it could be stamped.
Users browsing this forum: BBY755 and 76 guests
