It is currently Sat Aug 16, 2025 5:48 pm
 Post subject: Rocker pads
PostPosted: Thu May 01, 2008 9:53 pm
Can you but new rocker pads? Or can they be refaced and if so how do you do that?
Cheers Pete
PostPosted: Mon May 05, 2008 6:06 pm
you reface them
The machine is the same as they do valves on
you mount the rocker of shaft adjust to the corect arc and give them a very minor skim as you do not want to go thru the hardening.
Any good engine recondtior should be able to help
Thanks
Kiwiinwgtn
Users browsing this forum: No registered users and 231 guests
