It is currently Thu Aug 07, 2025 6:55 am
 Post subject: rubbin's NOT racin'
PostPosted: Fri May 02, 2008 5:20 am
finally got around to inspecting the Mini after the Wakefield run back in November. yeah i know :oops:
problem = right rear tyre was rubbing on the outside guard lip. Wakefield is mostly r/h turns so on 2 turns it was rubbing. i have adjustable brackets set to 0.5deg neg camber.
I have thought of a few possible causes
- being drivers side the huge 75kg lump that is me was weighing that side down too much.
- standard trumpets, but sits reasonably low. old cones may be squished too much.
- car is whacked. this is unlikely as Greig Malaure reckoned it was very straight when he set the suspension up. less than 0.25deg toe in one side and 0 deg the other.
- camber bracket came loose. unlikely as it is all tight as it should be.
anything obvious i am missing?
michael
 Post subject: Squatting...
PostPosted: Fri May 02, 2008 9:02 pm
Does it have rear competition bumpstops :idea:
PostPosted: Fri May 02, 2008 11:30 pm
negative
but i thought they were for hydro cars only. mine is dry. do people fit them to dry cars?
where exactly do they go?
at least no one has said i am heavy on that side :lol:
michael
 Post subject: Camber
PostPosted: Sat May 03, 2008 8:09 am
quote="mickmini"]negative camber?
Look ....http://www.minimania.com/web/STSearch/S ... entory.cfm
where exactly do they go? on top of the rear swing arm
at least no one has said i am heavy on that side :lol: probably because you are heavy on either side :?: :lol:
Cheers, Mick
PostPosted: Sat May 03, 2008 6:15 pm
no you misread that Mick. I said negative in that i do NOT have competition bumpstops.
I DO have negative camber brackets set to -0.5deg.
the link to Minimania is just like everywhere else and states that the rear bumpstops are for hydrolastic. I do NOT have hydrolastic. I have dry suspension.
And on top of the swing arm is not an exact location. Are they at the axle end, the pivot end, somewhere in the middle? Sorry the engineer in me wants to understand the problem before i do a suck it and see approach to solutions. I am not one for easter egging to get something working.
Who has fitted competition bumpstops to the rear of their dry car? Any pics?
michael
 Post subject: Joshin...
PostPosted: Sat May 03, 2008 10:28 pm
quote="mickmini" no you misread that Mick....nah just joshin around...
I said negative in that i do NOT have competition bumpstops...yeah, got that, just playing with words...
I DO have negative camber brackets set to -0.5deg...Check :!:
the link to Minimania is just like everywhere else and states that the rear bumpstops are for hydrolastic. I do NOT have hydrolastic. I have dry suspension....why you you no look proper grasshopper :!: REAR BUMP STOP KIT DRY MINI & MINI COOPER S C-SRP015 - $69.95
And on top of the swing arm is not an exact location. Are they at the axle end, the pivot end, somewhere in the middle? Yes..somewhere in the middle!!
the other michael :D
PostPosted: Sat May 03, 2008 11:35 pm
aah they were there after all. :oops: got a lotta things on my mind atm
Still, i would like to know who has found it necessary to fit the rear bumpstops. i hate fixing symptoms of problems and not the cause. Anybody had this kind of rubbing on one side only?
com on there are plenty competition cars out there with dry suspension. Anybody?
Bueller? Bueller?
michael
PostPosted: Sun May 04, 2008 7:22 am
I run the hydro comp bumpstops on the rear of my dry mini, but I used the hydro arms :) Not done it because I had to, I had a set of bump stops and they bolted up. I shortened the bumpstops by about 3/4" too, due to my ride height, the body was in contact all the time.
Listening to your circumstances, suggest your rubber cones are shot. Replace them and then see if you need the bump stops.
Steve
 Post subject: Twumpet
PostPosted: Sun May 04, 2008 10:03 am
Yeah...or a trumpet has partially collapsed/punched through its cup.
PostPosted: Mon May 05, 2008 6:31 am
i think i have to drop the subframe to replace the battery box anyway. will have a good look at it then...
apart from the rubbing it handles like a demon the way it is.
michael
PostPosted: Mon May 05, 2008 7:55 am
Have you rechecked all the alignments after it's trip up there ? Wonder if the container got a bump in the right direction to put something out a smidgen , just enough to make it rub under the right conditions .
PostPosted: Tue May 06, 2008 3:14 am
it was rubbing at Wakefield before it got into the container. there is a line all the way around the tyre. it has to be rolling to get that :wink:
I am going the replace cones route at this stage and will see what happens.
