It is currently Mon Aug 18, 2025 12:30 am
 Post subject: Battery isolator
PostPosted: Sun May 04, 2008 7:30 pm
ok noob question time
we're got several cars here that only get out occassionally so I'm looking to put an isolator on the battery cables.
qestion is - am I better to put the isolator on the earth or the power cable (some positive earth cars some negative eath)
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
 Post subject: Re: Battery isolator
PostPosted: Sun May 04, 2008 7:41 pm
This space for rent
Intuitively, I'd suggest it doesn't matter -- you should be able to break the circuit on either the +ve or -ve terminals and achieve the same effect.
PostPosted: Sun May 04, 2008 8:36 pm
I found the earth cable easier to do, and more accesible for dis-connection/connection :wink:
[img][img]http://i187.photobucket.com/albums/x4/olsenp/Picture.jpg[/img][/img]
