Rubber Rocker Cover Gasket https://www.ausmini.com/forums/viewtopic.php?f=2&t=41677 |
Author: | Rodney [ Sun May 04, 2008 4:21 pm ] |
Post subject: | Rubber Rocker Cover Gasket |
I believe that a rubber gasket between the head and rocker cover has been unavailable now for years. I like the thought of this so I made one. It's been on now for a couple of weeks with no oil leaks. I decided to do this because every time you check/adjust your tappets (service time), you need to replace the cork gasket. Not that it's expensive, but I like the thought of not having to replace it every time the rocker cover comes off. I know of one other ausmini member that has had his rubber gasket for something like 10 or 12 years - I wonder how long mine will last ![]() Hooroo |
Author: | sgc [ Sun May 04, 2008 4:57 pm ] |
Post subject: | Re: Rubber Rocker Cover Gasket |
Rodney wrote: I believe that a rubber gasket between the head and rocker cover has been unavailable now for years. I like the thought of this so I made one.
What grade & thickness rubber did you use? I can feel a visit to Clark's coming on ![]() |
Author: | Morris 1100 [ Sun May 04, 2008 5:16 pm ] |
I re-use the cork gaskets. I don't have any problem with them. But you must fit them in a certain way so that they will not break. 1) Clean the rocker cover surface with a solvent. 2) Glue the gasket to the rocker cover with contact adhesive. (following the directions so that the glue will work properly ![]() 3) Apply non-hardening aviation sealant to the gasket face. 4) Fit cover to the head. (as many times as you wish) When you re-fit the cover just apply some more non-hardening aviation sealant if needed. |
Author: | AEG163job [ Sun May 04, 2008 8:53 pm ] |
Morris 1100 wrote: I re-use the cork gaskets.
What a tight-arse! ![]() ![]() ![]() Good tips, do it all the time, no leaks. |
Author: | simon k [ Sun May 04, 2008 8:58 pm ] |
I always reuse my cork gaskets... I don't think I've ever used anything to seal them, I just do them up until it feels tight enough. I have a mate who once jumped up and down about the right torque 5 lb/ft! |
Author: | Rodney [ Mon May 05, 2008 6:44 pm ] |
The rubber I used was 5mm thick - came from a broken conveyor belt at work. Only trouble with it is the cotton all through the rubber, which is why I think it will leak, however, so far, so good. Bit trickey to make, but be patient and you will win, should you decide to make one. |
Author: | Morris 1100 [ Mon May 05, 2008 6:50 pm ] |
Some rubber items do not like oil. The is why most rubber things in car engines are not rubber at all but neoprene. |
Author: | gafmo [ Mon May 05, 2008 7:14 pm ] |
this is what you are looking for http://cgi.ebay.com/ebaymotors/Silicone ... enameZWDVW I have a pair of tappet chest gaskets and still look new |
