It is currently Sun Aug 03, 2025 6:55 pm
 Post subject: Australian sills.....
PostPosted: Sun May 04, 2008 8:23 pm
Anyone know where you can get them?
PostPosted: Sun May 04, 2008 9:06 pm
I got 2 from Anthony at http://www.minisport.com.au/index.htm
cost about 70-80 each
http://miniownersclubwa.com - http://members.iinet.net.au/~cleathley/pimpmymini/
PostPosted: Sun May 04, 2008 9:07 pm
try A grade panels - he has them made, but they come just as a flat folded panel - IE without a hole cut for the jacking point and no vent pressings
PostPosted: Sun May 04, 2008 9:43 pm
just measure them and go to a sheetmetal place.
they dont have dimples or anthing but at 40$ for 2 I dont really care :D
blokeinamoke wrote:
PostPosted: Sun May 04, 2008 10:30 pm
i got my ones custom, by custom i mean made up
PostPosted: Mon May 05, 2008 6:12 pm
ausmini mod
ausmini mod
They are NOT a straight part... if you look you will see that they are actually curved to match the body... for $70 odd, you should grab em
Peter.
PostPosted: Mon May 05, 2008 7:07 pm
I did notice they were curved but the straight panels took on said curve once they were clamped in place. :D
blokeinamoke wrote:
PostPosted: Mon May 05, 2008 9:20 pm
ditto... the ones from A grade are straight too, as are the UK ones I bought for my traveller - 1/2" an inch or whatever isn't hard to pull in over that length
PostPosted: Mon May 05, 2008 10:08 pm
I have known people who folded them up using a high school sheet metal bender... Two folds and you're away!
PostPosted: Mon May 05, 2008 10:16 pm
many years ago i made some out of gal steel folded pop riveted on painted with black mastic on the inside and painted with black bitumen on the outside no one new i also fiberglassed the floor .not these days :)
PostPosted: Tue May 06, 2008 12:06 pm
I folded my own out of some galv sheet, pretty easy and its not too hard to put a slight curve in them. You can always curve them a bit more when fitting them :)
Don't seem to have any pics of them finished though
