It is currently Sun Aug 10, 2025 9:04 pm
PostPosted: Sun May 04, 2008 4:21 pm
I believe that a rubber gasket between the head and rocker cover has been unavailable now for years. I like the thought of this so I made one. It's been on now for a couple of weeks with no oil leaks.
I decided to do this because every time you check/adjust your tappets (service time), you need to replace the cork gasket. Not that it's expensive, but I like the thought of not having to replace it every time the rocker cover comes off.
I know of one other ausmini member that has had his rubber gasket for something like 10 or 12 years - I wonder how long mine will last :?:
Hooroo
Rod Image
PostPosted: Sun May 04, 2008 4:57 pm
This space for rent
What grade & thickness rubber did you use? I can feel a visit to Clark's coming on ;)
PostPosted: Sun May 04, 2008 5:16 pm
I re-use the cork gaskets. I don't have any problem with them.
But you must fit them in a certain way so that they will not break.
1) Clean the rocker cover surface with a solvent.
2) Glue the gasket to the rocker cover with contact adhesive. (following the directions so that the glue will work properly 8) )
3) Apply non-hardening aviation sealant to the gasket face.
4) Fit cover to the head. (as many times as you wish)
When you re-fit the cover just apply some more non-hardening aviation sealant if needed.
PostPosted: Sun May 04, 2008 8:53 pm
What a tight-arse! :lol: :lol: :lol:
Good tips, do it all the time, no leaks.
PostPosted: Sun May 04, 2008 8:58 pm
I always reuse my cork gaskets...
I don't think I've ever used anything to seal them, I just do them up until it feels tight enough. I have a mate who once jumped up and down about the right torque 5 lb/ft!
PostPosted: Mon May 05, 2008 6:44 pm
The rubber I used was 5mm thick - came from a broken conveyor belt at work. Only trouble with it is the cotton all through the rubber, which is why I think it will leak, however, so far, so good.
Bit trickey to make, but be patient and you will win, should you decide to make one.
Rod Image
PostPosted: Mon May 05, 2008 6:50 pm
Some rubber items do not like oil. The is why most rubber things in car engines are not rubber at all but neoprene.
PostPosted: Mon May 05, 2008 7:14 pm
this is what you are looking for
http://cgi.ebay.com/ebaymotors/Silicone ... enameZWDVW
I have a pair of tappet chest gaskets and still look new
Users browsing this forum: No registered users and 156 guests
