no brakes https://www.ausmini.com/forums/viewtopic.php?f=2&t=4175 |
Author: | sean [ Thu Jan 20, 2005 6:12 pm ] |
Post subject: | no brakes |
just bought a 1977 clubman Biggest job is the brakes. They don't work at all until right at the end of travel of the pedal even then they are v poor. Handbrake seems to work ok. Any ideas on where to start solving the problem. Please help I want to drive it Sean |
Author: | brickworx [ Thu Jan 20, 2005 6:15 pm ] |
Adjust the brakes, read the manual if you have one. If the pedal doesn't then come up, try bleeding. |
Author: | Morris 1100 [ Thu Jan 20, 2005 6:25 pm ] |
Check that the clevis pin has not fallen out, it connects the brake pedal to the master cylinder. I had a Clubman that was missing the pin and mo matter what you did to the brakes (bleeding, adjustment) the brakes would only work on the very last bit of pedal travel. |
Author: | sean [ Thu Jan 20, 2005 6:29 pm ] |
how do I find the clevis pin |
Author: | poeee [ Thu Jan 20, 2005 6:41 pm ] |
Check each wheel cylinder to see if they aren't leaky. If you pump it up, does the pedal come up? Try bleeding them. Could be the master cylinder. |
Author: | sean [ Thu Jan 20, 2005 6:45 pm ] |
no the pedaldoes not pump up |
Author: | simon k [ Thu Jan 20, 2005 7:10 pm ] |
start simple, do the easiest things first - check the fluid, adjust each wheel, bleed them, then start checking the wheel cylinders etc,. |
Author: | sean [ Fri Jan 21, 2005 9:45 pm ] |
Post subject: | other jobs to do also |
Thanks for the advice everyone I will start soon as i have fitted a new high/low - any tips for that. Oh yeh lots of welding to do also - new sills bought today so welding and platepatching tips would also be most excellent |
Author: | 9YaTaH [ Fri Jan 21, 2005 10:34 pm ] |
Post subject: | top of the pedal |
sean wrote: how do I find the clevis pin
Up under your drivers side dash.....follow the brake pedal up....it is what conects the pedal to the master cylinder.... There is a whole thread on replacing it!!! search on Clevis..... |
Author: | drmini in aust [ Sat Jan 22, 2005 5:57 am ] |
Unless you are 4ft high or a contortionist, I'd pull the drivers seat out first... ![]() |
Author: | cush [ Sat Jan 22, 2005 8:26 am ] |
any girls out there wanna help sean find the clevis? |
Author: | lobby69 [ Sat Jan 22, 2005 11:17 am ] |
: any girls out there wanna help sean find the clevis? hahahah! |
Author: | nermil [ Sat Jan 22, 2005 5:32 pm ] |
i was told since i was a littlun that brakes are an optional extra on a Mini ![]() |
Author: | meeni [ Sat Jan 22, 2005 5:50 pm ] |
make sure u put the clevis pins on nice and tight coz it is such a pain in the arse to reach under there and put them in every time they fall out!!! ![]() |
