KBS Coatings (Rust Seal) https://www.ausmini.com/forums/viewtopic.php?f=2&t=41770 |
Author: | dannzhu [ Tue May 06, 2008 9:32 pm ] |
Post subject: | KBS Coatings (Rust Seal) |
Has anyone ever tried this product? Made in Australia by KBS Coatings. "Supposedly" better than POR15? Are these products actually stop rust? Daniel |
Author: | Rookiepilot [ Tue May 06, 2008 9:43 pm ] |
Yes. I have used both. I've used KBS and POR15 and I can't tell the difference except for the price. KBS is a lot cheaper and Australian owned. They stop rust by excluding air. |
Author: | dannzhu [ Tue May 06, 2008 9:51 pm ] |
So, how do you use it? Clean up a panel till it's bare metal, then cover with KBS or POR, then prep for paint? Daniel |
Author: | gafmo [ Tue May 06, 2008 10:11 pm ] |
I have been useing POR15...so I'll give this one ago now..just wish they had a Clear also dannzhu her you go http://www.kbs-coatings.com.au/3-Step-System.asp |
Author: | dannzhu [ Tue May 06, 2008 10:35 pm ] |
gafmo wrote: I have been useing POR15...so I'll give this one ago now..just wish they had a Clear also
dannzhu her you go http://www.kbs-coatings.com.au/3-Step-System.asp Yeah, I read that bit... I'm just not sure what happens next. After the seal, the surface is prepped up for paint right? But prepping involves sanding as well right? Doesn't it remove the seal? Daniel |
Author: | dbr11k [ Tue May 06, 2008 10:39 pm ] |
i thought you had to wipe it with metho after the application |
Author: | Wombat [ Wed May 07, 2008 8:53 am ] |
Clear is between white and silver in the colour chart ![]() |
