Rear camber brackets https://www.ausmini.com/forums/viewtopic.php?f=2&t=4183 |
Page 1 of 2 |
Author: | willy [ Thu Jan 20, 2005 9:25 pm ] |
Post subject: | Rear camber brackets |
Are these worth putting in for general handling? Would i notice much of a difference with the rear wheels cambered in (i do drive like a maniac). |
Author: | bigel nigel [ Thu Jan 20, 2005 9:27 pm ] |
wait a second did u just say u dont drive like a maniac dont you remember what happened that sunday on jetty road lol |
Author: | willy [ Thu Jan 20, 2005 9:28 pm ] |
Post subject: | Re: Rear camber brackets |
big willy wrote: (i do drive like a maniac).
Edit: I'm not a retard, i'm just SPECIAL. |
Author: | brickworx [ Thu Jan 20, 2005 9:28 pm ] |
I'll second that you drive like a maniac... but i'll let other people tell you about camber brackets |
Author: | willy [ Thu Jan 20, 2005 10:44 pm ] |
Anyone? Rear camber brackets. Cmon before steve forces me into something that I don't know much about. ![]() ![]() |
Author: | JC [ Thu Jan 20, 2005 11:11 pm ] |
There was a fairly lengthy post in the Mods section that contained alot of opinions on this. Do a search, you might get lucky. I have an adjusti set. $60 US. If that helps? |
Author: | supercharged 850 [ Fri Jan 21, 2005 1:39 am ] |
Chris has a much cheaper way of "making your own" camber brackets... Just slap a gutter. ![]() For driving on the road.... camber brackets are useless. Just increases the tyre wear. And YOU dont have good brakes so you wont be driving fast in the hills. For high speed corners at race speed on a race circuit..... very handy indeed. Have a think about it. |
Author: | gafmo [ Fri Jan 21, 2005 5:21 am ] |
I have a set which I purchsed from Karcraft..for Marcia She's not on the road yet so I can't give you a good idea yet sorry. |
Author: | drmini in aust [ Fri Jan 21, 2005 6:09 am ] |
I don't like 'em, most are about as strong as pushbike chain adjusters.. ![]() Did mine by filing the holes upwards in the brackets, MIG weld the bottom of the hole, then file hole for a neat fit on the shaft. You only want about 1* neg camber anyway, and for the road you probably will never move it again.. ![]() |
Author: | 1380 yellow devil [ Fri Jan 21, 2005 8:45 am ] |
I was looking at putting them on to prevent rear tyre wear. My rears wear on the insdie but I spose I cluld look at putting more shims in the orginal brackets also. |
Author: | simon k [ Fri Jan 21, 2005 11:22 am ] |
drmini in aust wrote: I don't like 'em, most are about as strong as pushbike chain adjusters..
![]() Did mine by filing the holes upwards in the brackets, MIG weld the bottom of the hole, then file hole for a neat fit on the shaft. You only want about 1* neg camber anyway, and for the road you probably will never move it again.. ![]() how much do you file 'em Kev? |
Author: | mickmini [ Fri Jan 21, 2005 11:31 am ] |
hey devil, make sure the bearings in the swing arms are not worn out before you start to fiddle with the camber. common cause of abnormal rear tyre wear, as is bent subframe. the idea of the camber brackets being discussed here is to add more negative camber, so the inside of the tyre will wear MORE if you put them in and drive mostly straight lines. i.e. not racetrack cornering. |
Author: | 1380 yellow devil [ Fri Jan 21, 2005 11:44 am ] |
My Devil drives very straight now just a small amount of wear on theinsides but by the time the tyres are worn out the wear on the inside is just on the bald side. not too bad tho |
Author: | drmini in aust [ Fri Jan 21, 2005 6:37 pm ] |
skssgn wrote: drmini in aust wrote: I don't like 'em, most are about as strong as pushbike chain adjusters.. ![]() Did mine by filing the holes upwards in the brackets, MIG weld the bottom of the hole, then file hole for a neat fit on the shaft. You only want about 1* neg camber anyway, and for the road you probably will never move it again.. ![]() how much do you file 'em Kev? From memory, 5mm gives about 1*. Get the car checked on a wheel aligner or camber gauge, before you start. Mine needed 5mm one side and 7mm the other to get 1* negative. |
Author: | 9YaTaH [ Fri Jan 21, 2005 6:43 pm ] |
Post subject: | Three Wheel Alignments |
drmini in aust wrote: skssgn wrote: drmini in aust wrote: I don't like 'em, most are about as strong as pushbike chain adjusters.. ![]() Did mine by filing the holes upwards in the brackets, MIG weld the bottom of the hole, then file hole for a neat fit on the shaft. You only want about 1* neg camber anyway, and for the road you probably will never move it again.. ![]() how much do you file 'em Kev? From memory, 5mm gives about 1*. Get the car checked on a wheel aligner or camber gauge, before you start. Mine needed 5mm one side and 7mm the other to get 1* negative. 1. Check rear Camber on aligner 2. Mod arms accordingly 3. Check wheel alignment before welding up elongated holes? 4. Weld up holes 5. Final check of alignment?? dat right????? 2. |
