Sump guard https://www.ausmini.com/forums/viewtopic.php?f=2&t=41846 |
Author: | Kennomini [ Fri May 09, 2008 3:12 pm ] |
Post subject: | Sump guard |
I'm pretty sure this is a Moke sump guard and I want to fit it to a mini subframe. Is their a difference between the two subframes (Moke-mini)? because it doesn't seem to line up fully ![]() ![]() ![]() I think it will still fit fine but what do yous think ![]() |
Author: | simon k [ Fri May 09, 2008 3:17 pm ] |
pfft, attach it at the front, then put the jack under it.... it'll fit properly quickly enough you don't live in a warm climate do you?? |
Author: | Kennomini [ Fri May 09, 2008 3:30 pm ] |
Theirs actually no bolt holes in the rear section only in the front and side wings which all fit perfectly ![]() ![]() |
Author: | Mike_Byron [ Fri May 09, 2008 3:50 pm ] |
Then put bolt holes in the rear section because one day your going to catch it in reverse and do a lot of damage. Apart from that its likely to flap underneath - sound annoying and eventually fatigue crack either the sub frame and the sump guard mounts. |
Author: | gafmo [ Fri May 09, 2008 7:51 pm ] |
Yep I would drill holes in the subby up the back so it would not catch when reversing ![]() |
Author: | Kennomini [ Sat May 10, 2008 12:07 am ] |
I might see if some of those "cotton wheel" rubber mounts fit the gap. |
Author: | TheMiniMan [ Sat May 10, 2008 12:43 am ] |
Kenno,,, if you fit that moke sump guard to a mini then you will be hitting just about every bump in the road with it,,, they are WAY too low for the average mini just grab a decent "mini" one |
Author: | gafmo [ Sat May 10, 2008 6:41 am ] |
Didn't know they were deaper |
Author: | sports850 [ Sat May 10, 2008 6:59 am ] |
Yes , they don't fit as snuggly to the gearbox as the nice mini ones do , probably sit about an inch lower than a bare sump and all those things that you just got over you now don't .... |
Author: | Kennomini [ Sat May 10, 2008 12:41 pm ] |
But with something that solid I'll just ski over those hurdles ![]() |
Author: | Mick [ Sat May 10, 2008 1:02 pm ] |
They're marvellous for catching the oil leaks too. Then the dirt gets into it and you have to shovel it out down the track... |
Author: | Davo111 [ Mon May 12, 2008 9:56 pm ] |
Post subject: | No drips for me |
so thats why I don't have any drips on the floor after 8 months, thought I had a good sealed motor from Steve, now I will have to start cleaning the top of the sump guard as well as the dip stick. ![]() |
Author: | Davo111 [ Mon May 12, 2008 9:57 pm ] |
Post subject: | One 2 many. |
Hey mick, don't you have 1 to many cars on your signature list.... |
