gear thing https://www.ausmini.com/forums/viewtopic.php?f=2&t=41872 |
Author: | carter [ Sat May 10, 2008 10:28 am ] |
Post subject: | gear thing |
ok i want to know if the inner part rod thing in the solid change extension is the same a s i morris 1100 s( but was a 1275) or what ever it is called the one with the same extension but the holes are different from the mini extension....... i hope this makes sense...... any help appreciated thanks justin |
Author: | Mike_Byron [ Sat May 10, 2008 12:10 pm ] |
Yes the inner rod is the same - the remote casing is different as you have noted Mike |
Author: | carter [ Sat May 10, 2008 4:12 pm ] |
ok thanks a lot mike......... |
