It is currently Mon Jul 21, 2025 11:20 pm
PostPosted: Sat May 10, 2008 2:08 pm
As above, what are the best ones for a standard small bore? It will be getting a Minispare's alloy inlet manifold and twin box RC40 exhaust.
Cheers Pete
PostPosted: Sat May 10, 2008 2:17 pm
Maniflow - tried and tested...have tried perry and the cheaper clones...went back to Maniflow.
RC40 is a good choice though - go the twin box - believe it or not they make 1-2 more hp than the single RC40 rear box(according to Visard that is...)
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sat May 10, 2008 2:25 pm
I couldn't believe the difference a set of maniflows made to the note coming through an RC40...a nice combination.
PostPosted: Sat May 10, 2008 2:56 pm
So these are the ones to get then?
Cheers Pete
http://www.minisport.com.au/prod73.htm
PostPosted: Sat May 10, 2008 3:10 pm
This space for rent
Cheers Pete
No, I'd consider these:
http://www.minisport.com.au/prod847.htm
Those LCBs are more suited to a really hot 998 or a big bore, you might even find the 3-1 are better suited to a standard smallbore.
PostPosted: Sat May 10, 2008 4:32 pm
sgc wrote:
Cheers Pete
Granted and $10 bucks cheaper - I found the 3 into 1 easier to fit and no painful Y-piece but I have more power and low end torque on the LCB - but then I do also run a Dellorto so that is probably why...lol
I think anything is better than the standard pea shooter - when you get your original muffler off, cut it in half and look at the internals - Blocked comes to mind!!
Rob Forsyth
Miniot!!
PostPosted: Sat May 10, 2008 5:50 pm
yes, i have a standard 998 and i was thinking the 3 into 1 as a sort of stage one upgrade, would the sound be diffrent, if so how to a LCB, i thought that the diffrent noise eg louder or softer would have been from the type of exaust used?
PostPosted: Sat May 10, 2008 9:40 pm
Sounds completely different - whichever one you go - and for the better. All minis should have sounded like that!! :D
Rob Forsyth
Miniot!!
PostPosted: Sat May 10, 2008 10:14 pm
Rob, Mick, what's the OD of the header pipes of those 1 3/4" exit maniflows?
any idea?
PostPosted: Sun May 11, 2008 4:30 pm
proformance wise?
PostPosted: Sun May 11, 2008 4:43 pm
Dunno about the OD, Also can't put a figure on the improvement either, but they were better than the crappy 3 branch perrys I removed. Not a bad buy for a less than 250..
PostPosted: Sun May 11, 2008 8:45 pm
Cheers Pete
:D Yes they are the ones i'd fit on any size a-series engine especially if you are thinking further forward where you may put a larger bore a-series engine in your car.....even if it is only modifying the current engine in the car.
:shock: Oh and just so you know they DO clear rubber uni joints without modification to the pipes......only just clear but they do clear them none the less.
:lol: My 5 cents worth
PostPosted: Sun May 11, 2008 9:17 pm
I would still get LCB's even for a standard 998. Means you've got the best for when you mod the 998 further or fit a 1275.
PostPosted: Sun May 11, 2008 10:19 pm
This space for rent
Fair call actually, LCBs might not be the best extractors for a standard 998, but they'll be a damn sight better than the pea shooter.. and you've got the right bits for when you do crank up the tune 8)
