Best Extractor's for a standard 998 https://www.ausmini.com/forums/viewtopic.php?f=2&t=41877 |
Author: | EST-071 [ Sat May 10, 2008 2:08 pm ] |
Post subject: | Best Extractor's for a standard 998 |
As above, what are the best ones for a standard small bore? It will be getting a Minispare's alloy inlet manifold and twin box RC40 exhaust. Cheers Pete |
Author: | CPOCSM [ Sat May 10, 2008 2:17 pm ] |
Maniflow - tried and tested...have tried perry and the cheaper clones...went back to Maniflow. RC40 is a good choice though - go the twin box - believe it or not they make 1-2 more hp than the single RC40 rear box(according to Visard that is...) Hooroo |
Author: | Mick [ Sat May 10, 2008 2:25 pm ] |
I couldn't believe the difference a set of maniflows made to the note coming through an RC40...a nice combination. |
Author: | EST-071 [ Sat May 10, 2008 2:56 pm ] |
So these are the ones to get then? Cheers Pete http://www.minisport.com.au/prod73.htm |
Author: | sgc [ Sat May 10, 2008 3:10 pm ] |
deluxe_68 wrote:
No, I'd consider these: http://www.minisport.com.au/prod847.htm Those LCBs are more suited to a really hot 998 or a big bore, you might even find the 3-1 are better suited to a standard smallbore. |
Author: | CPOCSM [ Sat May 10, 2008 4:32 pm ] |
sgc wrote: deluxe_68 wrote: No, I'd consider these: http://www.minisport.com.au/prod847.htm Those LCBs are more suited to a really hot 998 or a big bore, you might even find the 3-1 are better suited to a standard smallbore. Granted and $10 bucks cheaper - I found the 3 into 1 easier to fit and no painful Y-piece but I have more power and low end torque on the LCB - but then I do also run a Dellorto so that is probably why...lol I think anything is better than the standard pea shooter - when you get your original muffler off, cut it in half and look at the internals - Blocked comes to mind!! |
Author: | bill.b [ Sat May 10, 2008 5:50 pm ] |
yes, i have a standard 998 and i was thinking the 3 into 1 as a sort of stage one upgrade, would the sound be diffrent, if so how to a LCB, i thought that the diffrent noise eg louder or softer would have been from the type of exaust used? |
Author: | CPOCSM [ Sat May 10, 2008 9:40 pm ] |
Sounds completely different - whichever one you go - and for the better. All minis should have sounded like that!! ![]() |
Author: | simon k [ Sat May 10, 2008 10:14 pm ] |
Rob, Mick, what's the OD of the header pipes of those 1 3/4" exit maniflows? any idea? |
Author: | bill.b [ Sun May 11, 2008 4:30 pm ] |
proformance wise? |
Author: | Mick [ Sun May 11, 2008 4:43 pm ] |
Dunno about the OD, Also can't put a figure on the improvement either, but they were better than the crappy 3 branch perrys I removed. Not a bad buy for a less than 250.. |
Author: | BALLISTIC [ Sun May 11, 2008 8:45 pm ] |
deluxe_68 wrote:
Author: | poeee [ Sun May 11, 2008 9:17 pm ] |
I would still get LCB's even for a standard 998. Means you've got the best for when you mod the 998 further or fit a 1275. |
Author: | sgc [ Sun May 11, 2008 10:19 pm ] |
Fair call actually, LCBs might not be the best extractors for a standard 998, but they'll be a damn sight better than the pea shooter.. and you've got the right bits for when you do crank up the tune ![]() |
