Please help with my HIF44 Carb
https://www.ausmini.com/forums/viewtopic.php?f=2&t=41953
Page 1 of 2
Author:  wyan [ Mon May 12, 2008 6:39 pm ]
Post subject:  Please help with my HIF44 Carb
Hello,
On saturday I changed my points dizzy to a lectronic one, got it running first go, after a fiddle with the timing it wasnt to bad, and driving fairly well dispite running a tad rich, I was realy pleased with it. Now today after replacing my oil feed pipe (nothing to do with it) my carb is missing abit about 1/2 revs and farting and so on. I leaned it right out, but its still farting and blowing smoke, not oil smoke but richness sorta smoke, I suspect its the timing more then anything, but any help would be greatly appriciated, its my only car and my closest mini guy probally cant fit me in for about 2 weeks, and I really need her to get to work
Thanks guys
Author:  simon k [ Mon May 12, 2008 7:29 pm ]
I wouldn't go jumping to the conclusion that the carb is the problem if you've only just installed the electronic distributor, even if it did work well to start with, how can you be sure it's working well now?
what process did you use to do your ignition timing when you put the distributor in?
if I was you, I'd put the carb back exactly how it was, and put your old distributor/coil back in to make sure it's not a problem with the new dizzy
Author:  wyan [ Mon May 12, 2008 7:48 pm ]
yeah I suspect twasnt the carb as much as the dizzy, the main reason I changed the dizzy (well besides having it sitting here because it wasnt put in with the engine transplant...which I wasnt a happy camper..anyway) is it was doin a similar thing before I changed to the leccy one. Then my timing light s**t it self today
Author:  gafmo [ Mon May 12, 2008 8:21 pm ]
what coil are you now using and is it getting hot. Also do have a Ballist attached to the Coil
Author:  brickworx [ Mon May 12, 2008 8:29 pm ]
On a HIF carby check the choke seal.
we have lots of problems with these leaking on older carbs.
Author:  wyan [ Mon May 12, 2008 9:04 pm ]
I have two coils ive tried, one I bought today a new GT40, and a pretty much brand spanker standard(i think.. they changed it when the engine was put in) the standard is in at again now, as when I connected up the GT40 it seemed to make it worse?? But i did get it better after that so I might try it again connected. The standard one has like a small (looks like a condenser sorta thing) with like an earth wire going to it all coneccted, its not very big, whilst the GT40 is just the one unit.
The choke seal, is that the seal where the shaft enters the body?
Im not to familure with this carb yet sorry, Ive only had it for a month or two
Author:  wyan [ Mon May 12, 2008 9:06 pm ]
sorry, I didnt meen to say get worse, just sorta amplified it... if you get what I mean....
Author:  gafmo [ Mon May 12, 2008 9:17 pm ]
can you take a photo of this please and I think you will need a GT40R
Also what oil have you got in the dash pot
Author:  wyan [ Wed May 14, 2008 7:33 pm ]
I wouldnt have a clue what oil is in the dashpot, as I didnt set-up the carb, but I know it has it in there.
Im not sure how to put pics up???
What is in involved with changing the choke seal?
Author:  wyan [ Sat May 24, 2008 11:36 am ]
ok, I got the carb overhauled and the problem is still there!
Any one?
Author:  tinymorris1969 [ Sat May 24, 2008 4:42 pm ]
wyan i reckon it could be something to do with timing man. if the carby has been overhauled but the problem is still there its something you touched. so possibly the timing maybe. i could never work out my hif carby so i always just left it and it ran fine. richen the mixture again and correct idle speed again and check timing. but its definately a fuel/spark problem. whats the air filter like? and air flow.
where abouts in sydney are you wyan?
Author:  TheMiniMan [ Sat May 24, 2008 4:47 pm ]
Firstly,,, what type of electronic distributor dod you fit? can you describe the what the innards of the dissy looks like for me?
Author:  wyan [ Sat May 24, 2008 5:11 pm ]
ok, I it got it running better, but still not 100%. I richended the mixture quite alot, and advanced the timing I have both a points dizzy, and a standard lucas lectronic one from a late rover (carb), the points are literally 1100kms old, and so is the dizzy, condenser, with a brand new GT40 coil.
It couldnt have been anything I touched i dont think, because the problem was getting worse and worse over the last few weeks, and i hadnt touched a thing. So after a few hours of searching, swaping from both types of dizzys, and adjusting timing/mixture, we put it down to the carby. In the end I went to midel for a quote, and the carb needed an overhaul, fair enough, it had probally been sitting in the UK for a while, The inards of the lectronic one just have the rotor button, then the cap has two screws that hold it on.
I have left the points dizzy on it now as it seems to be better with that one in rather then the lectronic one... Does this help?
Author:  wyan [ Sat May 24, 2008 5:13 pm ]
Sorry, forgot- my filter is a cone type, like a K & N? From Minisport UK
Author:  tinymorris1969 [ Sat May 24, 2008 5:17 pm ]
how much better is it with the points compared to the electronic? and wat condition is the filter in?
