It is currently Fri Jun 27, 2025 1:54 am
 Post subject: Dizzy question
PostPosted: Tue Jul 07, 2009 8:19 pm
i have a pulsar d4r83 dizzy which i sent up to grahram russell to modify the curve, at the time i had a 1098
now i am going to a 1293 do you think the dizzy will have to be rucurved? or just chuck it in.
thanks
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Tue Jul 07, 2009 8:58 pm
Ask Graham. I think for 1098s he takes both light springs out, and for a 1275 he takes 1 light spring out. The centrifugal advance plate degrees is about the same for both, 9° or so.
I would try it first like it is, but if it pings just above idle put one light spring back in.
PostPosted: Tue Jul 07, 2009 9:36 pm
Doc,,, there`s only 2 springs in there,,, ????
PostPosted: Tue Jul 07, 2009 9:48 pm
Nope there are 4 springs. There are 2 light and 2 heavy. Inside each other. :wink:
PostPosted: Tue Jul 07, 2009 10:58 pm
interesting...
is this the same for a 29d, i have one in pieces ready to rebuild, and when it was taken apart, one light spring on one side, and one heavy spring on the other, only two springs all up.
PostPosted: Tue Jul 07, 2009 11:06 pm
oops,,, my bad,,, didn`t see the type of dizzy (Hitachi) , my bad & i stand corrected yet again :-)
PostPosted: Wed Jul 08, 2009 8:13 am
You don't have to stand on our account Matt - you can sit on your laurels :roll:
David L
PostPosted: Wed Jul 08, 2009 9:43 am
i used to have a girlfriend called Laurel,,, :-)
Users browsing this forum: Bing [Bot] and 88 guests
