Fitting the Morris bonnet badge https://www.ausmini.com/forums/viewtopic.php?f=2&t=42052 |
Author: | Ben_Aus_Mini [ Thu May 15, 2008 2:28 am ] |
Post subject: | Fitting the Morris bonnet badge |
I bought the badge and when I tried to insert the 2 pins into the holes, the pins were actually a bit further apart than the holes (no more than 1mm apart i think) , so couldn't get the 2 pins in the 2 holes at the same time except the most most likely way is by forcing them through. And I dun want to use 'brutal' force so will chip the paint off. Is this a problem common and how to solve it? What is the proper way to fit a Morris bonnet badge to the Mini bonnet. Thanks. |
