It is currently Sat Jul 19, 2025 3:00 pm
 Post subject: offsets
PostPosted: Thu May 15, 2008 7:24 am
Hey all,
I swear I saw this a while ago but I searched and searched adn could not find it.
I am looking at some wheels that are a bit ...errr diffferent for the mini and not sure if the offset will work.
What is the best offset for 13X6?
PostPosted: Thu May 15, 2008 9:58 pm
anyone?...
 Post subject: Re: offsets
PostPosted: Thu May 22, 2008 11:44 pm
If you want it to handle well you'll need to tuck them in as far as possible. The limit is the rear tyre clearance to the trailing arm. If you are using brake drums with the built-in spacer the wheel offset will need to be about ET26.
