It is currently Sat Jul 19, 2025 3:03 am
 Post subject: cooper s facts
PostPosted: Fri Jan 21, 2005 11:25 pm
Hi, might of found a cooper s available and was wondering what years they were manufactured and any bits of advice on what to look for to see if it is genuine. Unfortunately am working through a third party and cant view the vehicle as of yet without a really long drive. Does anyone have any info on coopers or a link to a website?
If it squeaks and leaks, then its sure to be a mini
Building a dream one nap at a time....
http://spaces.msn.com/members/derbydog/
PostPosted: Fri Jan 21, 2005 11:43 pm
there have been several topics about seeing if it's genuine, I'll give you a few, do a search and more will appear - first things to check is there is a little hole under the left-hand side of the cavity under rear seat, facing towards the rear of the car - only S's were supposed to have them, there's an opinion that some 850's had it as well, but there are other ways to tell an 850...
other than the normal stuff like twin tanks, front disk brakes etc... there are lots of special things to check - too many to list!
MK1 S's went from '65 to mid '69, and MK 2's went from mid '69 to early '71
for a MK1 the body number stamped into the firewall (I think) should start with YG2S2, the compliance plate will have YKG2S2, a MK 2 will have YG2S4 stamped into the top of the radiator shroud and no compliance plate other than one on the right hand side of the engine bay behind the brake booster which should be fitted. A MK1 engine number starts with 9FSAY, a MK2 starts with 9FXEY
there should be a diagonal brace behind the grille to clear the oil cooler, the mounting for the oil cooler should have a bent over section of the panel behind the grille, and under the front scuttle there should be bracings for the bracket that is under the oil cooler, unless it's a very early '65 model, in which case the oil cooler is mounted on the side of the oil filter housing
look for a white wire in the rear half of the loom behind the wiper motor where it connects to the front loom - the white wire is for the electric fuel pump, only S's and 850's had an electric pump, though my first S was a genuine shell and the white wire was missing - the rear loom may have been replaced.
Check in the boot - the bootlid itself should have a black cardboard panel screwed to it, if the panel is missing, you should see a series of maybe 25 holes drilled all around the edge of it where the panel screwed on.
the brackets for the boot board should be neatly riveted in place
there should be tabs around the rear firewall that hold the fuel tank breather tubes - look for 2 sets of them for the 2 tanks
PostPosted: Sat Jan 22, 2005 12:01 am
Thanks thats a great help, for the moment I should be able to get a chasis number hopefully in a week or so. Also good to know what years they were made. I knew about the disks but the fuel tanks etc is new to me only had the mini bug for a yr or two and had the clubby about a year so still learning.
PostPosted: Sat Jan 22, 2005 1:58 pm
Hi,
In the "Mini Experience" magazine, there is quite a bit of information about the early Mark 1 Cooper S, alot of that information relates to the Mark 2.
Good reading.
Users browsing this forum: Bing [Bot] and 105 guests
