It is currently Sat Jul 19, 2025 9:56 am
PostPosted: Sat May 17, 2008 10:15 pm
Daffodil 1275
Hi All
Just after a recomendation on what sort of brake master cylinder is best. I have 8.4 single pot disks on the front drums on rear. Are they all pretty equal or are there some I should avoid.
Cheers Phill
KillaWatt Converions
"E"Mini, 144volt, 600 amp, 86kw from the get go
PostPosted: Sat May 17, 2008 11:38 pm
they're all about the same :wink:
I guess a recommendation is don't get a tandem one...
PostPosted: Sun May 18, 2008 9:18 am
Why not Simon - I am hooking up my disc brakes to the tandem system for the drum set-up on the S - is there something I dont know about?? Is this a problem using the tandem system on the disc brakes?
It is a genuine question - I dont want to be fiddling with a clevis pin again!!!! :x
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun May 18, 2008 11:41 am
I ran Cooper S Disks on my 78 with a tandem cylinder without any worries at all. Of course you have to run without a booster, or maybe with 2 :shock: but I loved my Disks un-boosted, nice feel and worked a treat.
We're about to do the same to our 76 as well.
Dicko
PostPosted: Mon May 19, 2008 11:14 am
nah, I don't think there's anything wrong with them, just if you don't have one already, don't get one cos (more complicated than a normal one etc. etc.)
I've got one to put on my conversion, the engineer said I had to have tandem...
PostPosted: Mon May 19, 2008 11:30 am
Would the weight of the car have any impact on the brake type used?
Eg, on a stock 850, drums and no booster are fine because the car is so light,
but on a later car with 8.4s, big wheels and generally more weight everywhere,
would an un-boosted non tandem setup work well?
It's something for my project car I've never decided.
PostPosted: Mon May 19, 2008 11:46 am
Can't you just run the booster on the front circuit? Or better yet, get a dual circuit VH44J booster, that you can run on both front and rear circuits.
PostPosted: Tue May 20, 2008 1:00 pm
Booster works fine on the front circuit only.
When the chips are down, under hard braking the rears do SFA anyway.
<edit> typo
Last edited by drmini in aust on Tue May 20, 2008 3:51 pm, edited 1 time in total.
PostPosted: Tue May 20, 2008 2:52 pm
When the chips are down, under hard breaking the rears do SFA anyway.
aside from locking up when they've got too much pressure
PostPosted: Tue May 20, 2008 4:50 pm
That's the original Cooper S/Innocenti B39/Clubman GT setup!
(With remote servo)
I use GMC227 tandem master (M10/M12 connections), Cooper S 7.5" disk brake, 1275GT servo (front circuit) and 17.5mm brake cylinders (1275GT size) at the rear.
Important is to run smaler brake cylindes at the rear to prevent over-breaking at the rear which can be quite dangerous!
And of course you need front/rear split circuits...
Jan
PostPosted: Tue May 20, 2008 5:16 pm
Asphalt wrote:
(With remote servo)
I'm not sure about later post 71 english models, but all cooper S Mk1, Mk2 were all single line. The booster took a feed direct from the master cylinder and pumped it back in at the t-piece next to the engine steady.
The only dual circuit cars we got down this neck of the woods was in the very late Clubmans.
