Blake, a 1360cc or a 1380cc engine is going to cost the same price as a std basic engine re-build, it`s just that you use 73mm (95thou) or 73.5mm (114thou) oversize pistons.
It`s best to have them offset bored so there is a more even amount of meat(iron) between all the bores & in fact it helps line up the cyls to suit the head gaskets because the head gaskets are allready made with that offset bore in mind
If you chose to go much bigger in the bore than those sizes then you risk having quite a flexy cyl block & quite a lot of piston ring blow by occurs & the end result is lots of crank case pressure & not as much power is produced than you would think because of the lost pressure past the rings from the bore flexure , also possible head gasket issues & & & etc etc etc blah blah blah
Soooooo,,, hence one of the reasons why we lengthen the stroke of the crank shaft (commonly called a Stroker & generally end up at about 84mm instead of the std crank stroke of 81.3mm) we are able to suck more gas in that way rather than going any bigger in the bore size.... Now in doing a stroker crank we end up spending quite a bit more on the crank mods, also switching con rods to suit & doing a far chunk of work on those too, maybe a bit of work on pistons to suit (depending on the application & the pistons chosen) etc etc etc blah blah blah
so, yeah, how long is a piece of string???... ok,,, well... in this case you can add approx upwards of $1500 to the cost of a std issue full power unit re-build cost
1360cc with stroker crank turns out to 1415cc-ish
1380 with stroker crank turns out to 1440cc-ish
there are many other options on piston sizes & stroke lengths to end up with varying engine capacities more or less than those i`ve described
--> EG: my own personal road engine bore is 160thou oversize (which would be 1426cc with a std stroke crank) but i`ve added an 86mm stroke crank which then makes it 1510cc-ish
My good mate & next door neighbour Stewys race engine is 1591cc (we call it a 1600cc)
I`ve known them to go as big as 1620cc & my dad has worked out a way to make one nearly 1700cc (don`t ask, there`s way too much involved for me to dribble on about here)
so,,, It`s only the constraints of the size of your wallet which determines the length of that piece of string
If you work on the average power unit re-build costing $4500-$5000-ish ,,, then add another couple of grand-ish & you`d be pretty close to the right money.
