It is currently Fri Jul 18, 2025 9:22 am
PostPosted: Wed May 21, 2008 7:07 pm
I'm thinking about doing a buy from Newton Commercial. But would like to know if the English interior door panels for a MK1 or 2 will fit my Deluxe. I'm guessing no. Because of the window winders and handle and that. But I will be buying the rear bin liners because they should fit and they are cheaper than me doing my own (IMO).
PostPosted: Wed May 21, 2008 7:28 pm
Front door cards are different, rears are slightly different (bugger all really).
Carpets and headlinings are different.
:D
PostPosted: Wed May 21, 2008 8:24 pm
If you tell them its for an Aussie mini , with windup windows , they will make them for you , they have the pattern for Aussie front door cards . The only difference then will be the material , the Aussie minis had a kind of vinyl , the Newton ones are made of the same material as the seat trim ( looks much nicer anyways) and are a little thicker. Because of this the front and rear cards are a little harder to fit , mainly into the top rail........ all the other interior trim panels fit perfectly . Newton Commercial do a lovely job of the trim :D
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Wed May 21, 2008 11:14 pm
nothing a pair of scissors and a step mother proficient in sewing can't fix..
