tacho https://www.ausmini.com/forums/viewtopic.php?f=2&t=42241 |
Author: | mad-mk1 [ Tue May 20, 2008 11:20 pm ] |
Post subject: | tacho |
hey guys, what is teh diode taht i need for the mini to make the tacho behave properly? and where would i find one? cheers jamie |
Author: | simon k [ Wed May 21, 2008 10:15 am ] |
what sort of tacho is it? mine doesn't need one ![]() |
Author: | mad-mk1 [ Wed May 21, 2008 10:36 am ] |
its a monsta brand one of ebay. i ahve seen posts on here about adding resistors etc to fix t |
Author: | Wombat [ Wed May 21, 2008 11:58 am ] |
A general purpose diode should be OK - depends on the current being drawn you can get them in 1 amp or 3 amp and the voltage rating can be 400 or 1000 volts If you want to be safe grab a 3amp 1000volt - 25cents won't break the bank and you have some overkill to help cope with the heat if it's in the engine bay that's a 1N5408 or a 1Amp 400 volt is 1N4004 - most commonly used yet is 40c each ![]() edit; Jaycar prices |
Author: | Hanra [ Wed May 21, 2008 12:50 pm ] |
Go the whole hog and get a BYW96E |
