It is currently Mon Jun 23, 2025 9:42 pm
 Post subject: brake master cylinder
PostPosted: Fri May 30, 2008 8:48 pm
Would a 76 clubby have a single or dual circuit master cylinder
PostPosted: Fri May 30, 2008 8:53 pm
From memory it would have a single circuit. I think the changeover was mid 77. (the 76 that I have here is a single circuit)
If it has no cylinder check the size of the hole in the bulkhead that the cylinder fits into. The dual cylinder has a bigger hole.
The dual cylinder cars will also have the brake failure light on the top dash pad. (as well as the handbrake light)
PostPosted: Fri May 30, 2008 10:25 pm
My 76 has a dual. They must have changed over sometime during the year.
