difference between clutch and brake cylinders?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=42360 |
Author: | yeehaa [ Sun May 25, 2008 11:40 am ] |
Post subject: | difference between clutch and brake cylinders?? |
could some one tell me how i can tellthe difference between a tin brake master cylinder and a tin clutch master cylinder????? cheers damian |
Author: | Hanra [ Sun May 25, 2008 11:56 am ] |
I know there is a bore diameter difference with the plastic tanked master cyls. Not sure bout the tin tank ones though? |
Author: | Wombat [ Sun May 25, 2008 12:54 pm ] |
Brake has a 'control' valve to hold the pressure a bit longer - leave it out you have a clutch cylinder put it in for a Brake Cylinder. Hanra is right about bore sizes as well can't remember off the top of my head can someone else fill in? |
Author: | brickworx [ Sun May 25, 2008 12:55 pm ] |
Most common is 0.7" for brake and 0.75" for clutch |
Author: | Hanra [ Sun May 25, 2008 12:59 pm ] |
Clutch Master: ![]() Brake Master: ![]() |
Author: | drmini in aust [ Sun May 25, 2008 5:02 pm ] |
Apart from bore size as said and the restrictor valve in the brake MC, the tin tank ones are `handed', ie the base flanges are in different positions. When put together on the car, the spacing between the tanks is greater than the spacing between the MC bodies. |
