ahhhh rust https://www.ausmini.com/forums/viewtopic.php?f=2&t=42455 |
Author: | Leighton [ Tue May 27, 2008 9:44 pm ] |
Post subject: | ahhhh rust |
ok... i have a slight rust problem and need some advice from those wiser than me(not too hard) what is the best approach to removing surface rust on the roof gutters on a clubman- i have heard wire brushes work well...are there any other solutions??? cheers leighton |
Author: | Lazzz [ Tue May 27, 2008 10:00 pm ] |
Mate i have just done it to mine. Wire wheels are great, but extremely unsafe so be very careful when using one. I use POR-15 products for rust on my car. Google it - Awesome stuff. |
Author: | spraycanmansam [ Tue May 27, 2008 10:44 pm ] |
I've recently done my Mini ones and I've just done the ones on my Morris. Make sure you get any bog/putty/seam sealer out of the seam... Get something sharp and pointy and dig it out as water gets in behind and rusts out the seam ![]() |
Author: | miniDave [ Wed May 28, 2008 7:11 am ] |
spraycanmansam wrote: I've recently done my Mini ones and I've just done the ones on my Morris. Make sure you get any bog/putty/seam sealer out of the seam... Get something sharp and pointy and dig it out as water gets in behind and rusts out the seam
This is what I used after using a small wire wheel. A small screwdriver with a bend to get at the seams: ![]() Regards |
Author: | Blokeinamoke [ Wed May 28, 2008 7:46 am ] |
Thats a great pic - very artistic. I like the wire wheel marks too ![]() ![]() |
Author: | bnicho [ Wed May 28, 2008 9:12 am ] |
I use a broken hacksaw blade to scrape out the rain gutters. Works a treat and you can get it all the corners with it. Use flexible seam sealer to reseal, not bog! |
Author: | Ben_Aus_Mini [ Thu May 29, 2008 12:22 am ] |
bnicho wrote: I use a broken hacksaw blade to scrape out the rain gutters. Works a treat and you can get it all the corners with it. Use flexible seam sealer to reseal, not bog!
How about Sikaflex? Is this good? |
Author: | benoz [ Thu May 29, 2008 1:01 am ] |
same thing, sikaflex is 'a' leading brand of flexible sealer, possibly 'the' leading brand. The modern products are all very good though, I can't remember a complaint about any brand or product |
Author: | bnicho [ Thu May 29, 2008 11:27 am ] |
Yep, Sikaflex is very good. It's important that it's a quality paintable type, not the cheap crap from Bunnings for bathrooms etc. |
