It is currently Wed Jun 25, 2025 9:21 am
PostPosted: Fri May 30, 2008 8:20 am
Interesting way of spray painting small areas
http://www.docv.org/cgi-bin/news/newsscript.pl?record=44&template=site
David L
PostPosted: Fri May 30, 2008 9:56 am
if I have a small patch that needs painting I just grab me a mouthfull of paint a blow it on ala the aborigines.
It takes some practice but you end up with very minimal overspray if you squirt the paint out rather than blow it on.
:D
blokeinamoke wrote:
PostPosted: Fri May 30, 2008 5:13 pm
brilliant cause i just finished sanding back the rust, now i just need 400 litres of bog to rebuild the car :P
1962 850,Frog
PostPosted: Fri May 30, 2008 5:33 pm
There is a garden spray gun - usually copper bowel and brass pump- green handle - that pressurises as you pump - gives a very fine spray.
David L
PostPosted: Fri May 30, 2008 6:06 pm
at least it should keep the bugs of the new paintwork :lol:
Users browsing this forum: Majestic-12 [Bot] and 81 guests
