It is currently Sat Aug 02, 2025 2:46 pm
 Post subject: Moke radias arms info
PostPosted: Tue Jun 03, 2008 6:13 pm
More progress with the moke resto and first of many problems 2 be confronted with.
Question 1, Mokes with 13" wheels have a longer rear radias arm, correct?
Question 2, If I measure from the grease nipple to the centre of the rear Hub i get 37cm, is this a long arm?
question3, does anyone have a LHS 13" arm
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Tue Jun 03, 2008 6:20 pm
moke radius arms have 2 needle roller bearing instead off a bronze bush
PostPosted: Tue Jun 03, 2008 6:41 pm
13" Moke rear arms are easy to pick,,, the shocky mounting pin isn`t directly in-line/behind the axle (it`s a few inches back up the arm)
easy-peasy & yeah i`m pretty sure i have 2 brand spanking new 13" moke trailing arms in stock here (one Left & one Right)
 Post subject: mini1275
PostPosted: Tue Jun 03, 2008 7:42 pm
obcourse the shock mount is different didnt come to me at the time. ill give you a buz tomorrow about the Rear arms.
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Tue Jun 03, 2008 8:46 pm
I have a spare set - but the bushes are gone
 Post subject: mm1275
PostPosted: Tue Jun 03, 2008 9:03 pm
Havent ever replaced them before, Not 2 chalenging is it? anyone in melbourne
*Reasonable pricing
*I come to you..
Jay: 0431404607
 Post subject: Re: mm1275
PostPosted: Tue Jun 03, 2008 10:01 pm
Changing arms is easy.
Changing `bushes' in a 13" Moke arm is easy- they don't have any!
They have 2 needle bearings, one at each end.
Once you get the old ones out, it's all easy- no (*^&%$^ bush to ream.
8)
PostPosted: Wed Jun 04, 2008 7:48 am
bushes - bearing I know what I meant :P
