It is currently Sat Jul 19, 2025 6:14 am
 Post subject: Needle bearings....
PostPosted: Sun Jun 01, 2008 4:01 pm
How is the easiest way to remove needle roller bearings from the upper control arm?
I thought you could press them through but on closer inspection it looks like there is a sleeve that is part of the casting in the centre....not removable like the rear radius arm one....?
PostPosted: Sun Jun 01, 2008 4:36 pm
They will come out if you have a long enough drift. You can also use a dremel to cut a groove in the outer sleeve/race once you have removed the rollers.
Or if you have a go at it you may also be able to deform the outer sleeve/race by getting a small sturdy punch, chisel or screwdriver under the race from the end. If you can fold the entire race in on itself it will eventually just fall out.
Good luck.
PostPosted: Sun Jun 01, 2008 7:09 pm
I MIG weld a bolt into them with 6 or 8 tack welds, then pull them out with a nut and spacer.
:wink:
same as I do with trailing arm, or idler gear bearings.
PostPosted: Sun Jun 01, 2008 7:37 pm
Cheers Mick and Kev, the dremel done the trick :P
