Needle bearings.... https://www.ausmini.com/forums/viewtopic.php?f=2&t=42586 |
Author: | jasonf [ Sun Jun 01, 2008 4:01 pm ] |
Post subject: | Needle bearings.... |
How is the easiest way to remove needle roller bearings from the upper control arm? I thought you could press them through but on closer inspection it looks like there is a sleeve that is part of the casting in the centre....not removable like the rear radius arm one....? |
Author: | Mick [ Sun Jun 01, 2008 4:36 pm ] |
They will come out if you have a long enough drift. You can also use a dremel to cut a groove in the outer sleeve/race once you have removed the rollers. Or if you have a go at it you may also be able to deform the outer sleeve/race by getting a small sturdy punch, chisel or screwdriver under the race from the end. If you can fold the entire race in on itself it will eventually just fall out. Good luck. |
Author: | drmini in aust [ Sun Jun 01, 2008 7:09 pm ] |
I MIG weld a bolt into them with 6 or 8 tack welds, then pull them out with a nut and spacer. ![]() same as I do with trailing arm, or idler gear bearings. |
Author: | jasonf [ Sun Jun 01, 2008 7:37 pm ] |
Cheers Mick and Kev, the dremel done the trick ![]() |
