heater tap
https://www.ausmini.com/forums/viewtopic.php?f=2&t=42591
Author:  the bean [ Sun Jun 01, 2008 7:38 pm ]
Post subject:  heater tap
hi all
just want to know are heater taps hard to get does mini king have them myn is stuck
thanks
Author:  Morris 1100 [ Sun Jun 01, 2008 7:43 pm ]
The best option is to fit a Holden or Ford heater tap. You can get them from a good spare parts place (not Supercrap) They can just fit anywhere along the heater hose and not necessarily next to the heater.
But this time of year you can just remove the tap and fit the hose straight into the heater. It will work well till Summer comes. :D
Author:  gafmo [ Sun Jun 01, 2008 7:50 pm ]
just remove it if it summer or winter and hook the hose up directly. It only gives out heat when the fan is on any way :wink:
Author:  Mick [ Sun Jun 01, 2008 7:51 pm ]
In a clubby it fries your toes in summer if you have the heater hose piped straight through, fan on or not...
the forward movement of the car rams air through the heater leading to lobster toes.
Author:  minidrifter [ Sun Jun 01, 2008 7:52 pm ]
(not Supercrap)
uh-oh,
maybe thats why mines stuck :mrgreen:
Author:  Harley [ Sun Jun 01, 2008 8:06 pm ]
A clever one I saw was a heavy duty plastic sprinkler system tap.
Light, cheap and won't rust.
:D
Author:  gafmo [ Sun Jun 01, 2008 8:12 pm ]
Thats strainge as we have a clubby heater in ours and it doesnt do that :lol:
Author:  scotta_74 [ Sun Jun 01, 2008 8:38 pm ]
Post subject:  Re: heater tap
the bean wrote:
hi all
thanks
He has them in stock
Author:  Mick [ Sun Jun 01, 2008 8:46 pm ]
There is the flap to close off the air flow, but the foam used to act as gaskets in them are often decayed. So hot air leaks past when you drive.
Particulalrly noticeable on the 40 degree days of last summer :roll:
Author:  dbr11k [ Mon Jun 02, 2008 8:51 am ]
i alaways run mine without the tap, just wind down the windows in summer cause it gets a bit nasty, i only used the mini for driving to work anyways, which was like a kilometre and a half :lol:
