injection
https://www.ausmini.com/forums/viewtopic.php?f=2&t=42599
Page 1 of 2
Author:  xplosion77 [ Sun Jun 01, 2008 11:07 pm ]
Post subject:  injection
are the rover mini's a centre point injection or did they ever come out with a multi point injection set up.
if anyone has a photo of there manifold setup they could send me that would be great. as im interested to know how they are done
thanks Jacob
Author:  benoz [ Mon Jun 02, 2008 12:20 am ]
yeah there is single point injection (spi, 91 - 99) and multipoint injection (mpi, 99 - 02.) Same head though (mini 5 port) so MPI minis still had only 2 injectors. Both produced the same horsepower but the MPI had a little more torque
Author:  drmini in aust [ Mon Jun 02, 2008 7:51 am ]
I would call the Rover Mini's MPI setup a `TPI' system, it's not `MPI' in the accepted sense of 1 injector per cylinder. Just not enough intake ports... :lol:
Has anybody yet got serious power from an MPI?
A 5 port 1330 with 45 Weber has now made over 160HP at the crank on GR's engine dyno, a hard number to beat. OK, so it's not a road car... :wink:
Author:  Asphalt [ Mon Jun 02, 2008 8:32 am ]
Almost. SPI is from 1992 to 1996, and MPI is from 1996 to 2000 :)
For the MPI's manifold look here:
http://www.ausmini.com/forums/viewtopic.php?t=42575
And here:
http://666kb.com/i/az5rxbg5odcl5bzam.jpg
The SPI's manifold is this one:
Author:  DOZ [ Mon Jun 02, 2008 12:12 pm ]
This pic is the best from Ashpalt's links
My only comment is that 2 injectors is not enough for an engine that is going to rev.
Daniel
Author:  MiniBob [ Mon Jun 02, 2008 12:46 pm ]
I'll let you know how I get on :wink: How often does GR read his e-mail :?:
Author:  DOZ [ Mon Jun 02, 2008 1:31 pm ]
What is the rpm limit of your engine?
Daniel
Author:  KLAS [ Mon Jun 02, 2008 4:32 pm ]
1430ccm and 110HP, with homemade inlet manifold, a road car :wink:
the biggest problem is injection timing. with the factory 63HP engine you have 5 miliseconds at 6000 RPM to inject all the fuel the engine needs per cycle. thats why the MPi injectors are very big, very fast and difficult to controll.
the Rover engineers were aware of the problems with higher revs, so they made it more torquey
4 inlet ports would help a lot
Author:  MiniBob [ Mon Jun 02, 2008 4:38 pm ]
How about a seven port with Omex :?:
Author:  brickworx [ Mon Jun 02, 2008 6:09 pm ]
We are doing a Rover EFI computer with piggyback computer this week.
putting it on a warm 1.3 with a big ported head
it will be at minishow 2008 if anyone is interested.
Author:  TheMiniMan [ Mon Jun 02, 2008 6:13 pm ]
Just put a BMW twin cam motorbike cyl head on it & then all the injection stuff is easy-peasy :-)
Author:  brickworx [ Mon Jun 02, 2008 6:19 pm ]
4 in 4 out makes it easy
Author:  xplosion77 [ Mon Jun 02, 2008 9:59 pm ]
cool thanks guys for the reply with the information, i would like to know how hard it is to get one of the mpi manifolds cause i have so many ideas floating around in my head about wat i would like to do to my mini, like a efi system with a turbo setup
thanks anyway
Jacob
Author:  DOZ [ Mon Jun 02, 2008 10:16 pm ]
Bad idea - will cost you lots of money and pain - take my advice and buy a house.
If you must turbo it then keep the engine carby'd so it's easy to find people who can tune it for you.
If you want to go port EFI on an naturally aspirated engine then invest in Motec/Autronic or similar (so when you give up you can sell it for not much loss) and use 4 injectors. The twin point set-up only works well at low rpm and low load (relatively speaking) and is not for high rpm/power.
Have a look at Mokesta's manifold if you want a good starting point.
Daniel
Author:  Harley [ Mon Jun 02, 2008 10:19 pm ]
I know in the UK some people have supercharged an MPI mini engine, but at the end of the day, if big power is what you want, factory parts won't cut it.
