It is currently Sat Jul 19, 2025 3:25 am
PostPosted: Sun Jan 23, 2005 9:19 pm
Hi guys,
How hard is it to change cv joints? Does it take long?
Thanks!
Lynda and Beefa
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
PostPosted: Sun Jan 23, 2005 9:29 pm
oh no... pressure is on now to fit CV's...
PostPosted: Sun Jan 23, 2005 9:37 pm
The ones on my van were real easy to do. First I rang up place that does diffs and drive shafts, booked it in. Drove it to the appointment, left it there for the day. Went back at end of day, forked over moneys, drove home. Had the uni's done aswell.
U may be after a somewhat more cost effective option, that would be to do it yourself!
:lol: :lol: :lol: :lol:
dammit, the above post was what i posted... this is what happens when a woman uses a fellas computer and doesn't log out!
PostPosted: Sun Jan 23, 2005 9:39 pm
NAV-MAN
lterel01 wrote:
Hi guys,
Thanks!
Lynda and Beefa
It's not very hard with a good tool kit and a ball joint splitter (trust me it's worth it's weight in gold).
Do you have a workshop manual?
PostPosted: Sun Jan 23, 2005 9:41 pm
yes we have two workshop manuals and i have a ball joint spliter at work. shouldn't be too hard surely.
PostPosted: Sun Jan 23, 2005 9:44 pm
NAV-MAN
Nope not too hard at all as i've just completed NAV's CV's. Just read the manual get familiar with everything and take your time.
The CV itself takes a bit of persuasion (read BFH) to come off.
If the cv boots are a bit perished (even a little bit) now will be a good time to fit newies.
PostPosted: Sun Jan 23, 2005 11:18 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
ok what ya wanna do is
while the car is still on the ground remove the split pin outa the castle nut
get a real big breaker bar you may have to jump on it to crack it
then jack the car up remove wheel drop the steering arm then this is important when you split the ball joint do the bottom one first
i use a splitter for the steering joint the smallest splitter is the best . you need to drop the bottom first hmmm said that already but it is important cos if ya drop the top first it makes it a crap to get the bottom out ... i learned the hard way
if ya get into troble my number is 0412 938 072
makka
