It is currently Tue Jul 29, 2025 11:51 pm
 Post subject: Spark Plug Order
PostPosted: Sat Jun 07, 2008 12:16 pm
Hi,
I recently pulled the spark plug and distributor leads so i could clean the distributor up, but i have forgotten where each lead goes.
So can anyone help me, anyone have any pictures of the correct order.
Sav
73 Clubman - Working Progress
PostPosted: Sat Jun 07, 2008 12:42 pm
the order counter-clockwise is 1-3-4-2.
Usually 1 will be at the 2 o'clock position, but if it is not (the engine doesn't run)) there are technical (and non-technical ways) of working it out.
PostPosted: Sat Jun 07, 2008 6:33 pm
And number 1 is nearest to the radiator, the order is right to left looking at the engine
Daniel
PostPosted: Sat Jun 07, 2008 7:25 pm
Resident Haemorrhoid
If you make number 1 on the left above the clutch the firing order is
4-2-1-3 :wink:
mtsmini wrote:
Tombo wrote:
