I recently bought a 1969 Morris 1100 S Automatic and drove him back from Geelong to Canberra a few weeks ago....great drive (and then ran out of petrol 5 klm from my front door....have a laugh, I did)
Since then I have been reading that some things are hard to find.....particularly oil filters. The article below states that Triumph TR6 filters are only slightly shorter (3/8") and that by stretching the spring they work fine - that was the report rather than the writers experience.
The automatic was overhauled in Geelong in 2005 and appears to be OK. When cold it doesn't like reverse much or the 3rd/4th shift when in drive and flares 3rd/4th when changed manually...
When warmed up say after a couple of miles it is totally different.
He's running Castrol GTX....and will be changed at 1500-2000. The Gregorys manual says that I should be using 10/30 oil without modifiers and I have found that this
http://www.trubluoil.com.au/index.php?o ... &Itemid=74 seems to be about the only source....I particularly like that they TELL me that that there are no friction modifiers in it....
Would this help my changing issue?
I also feel that he is changing up too early and have read here
http://members.tripod.com/austin_america/id72.html (at UPDATE towards the bottom) that adjusting the 'kick down rod' can help this by keeping the revs higher....
any thoughts???
Kez
