It is currently Sun Jul 20, 2025 9:45 am
 Post subject: Blue slip?
PostPosted: Wed Jun 11, 2008 5:02 pm
Recently I replaced my 998 with a 1275. What do I have to do to adjust the rego? Blue slip only? Where can I get a blue slip from? My car has disk brakes. Thank you.
PostPosted: Wed Jun 11, 2008 5:14 pm
Yes , you will need a blue slip to change the engine number , I couldn't believe it last time I went , you used to be able to front up to the RTA with the receipt and they'd check it matched what it was supposed to but now you need the full blue slip to say the engine number is on the motor ...
PostPosted: Wed Jun 11, 2008 5:22 pm
you can get a blueslip from a mechanic shop that does blueslips alot of places do them my cost 50 dollars.
TUCK3R
PostPosted: Wed Jun 11, 2008 9:07 pm
Ring the RTA and they will fax you the list of Blue slip authorised inspection stations for your area.
Cheers Pete
PostPosted: Wed Jun 11, 2008 9:12 pm
Its not a full blue slip - they will only check the engine number and the compliance (identity) plates
Be sure they notate on the slip that you have disc brakes - they probably wont understand the significance.
That is unless the law has dramatically changed in the last two or three years
Mike
PostPosted: Thu Jun 12, 2008 2:21 pm
It shouldn't be anymore than 40 dollars.
It was about 28 - 38 dollars in NSW (couldn't exactly remember) cus I did it 2 months ago to rectify the engine number problem. Dunno how much in other states though.
Are you at NSW? If so I can find you the details of that person who did it. He's a pretty nice fellow. I rem he loved my car and ask if I wanna sell it to him.
Ben
1964 Morris Mini 850 - G13b gti powered - classic yet practical
1968 Morris Minimatic - 1100cc - classic & breakable
Sun Certified Java Programmer v5 310-055
