It is currently Sat Jul 19, 2025 9:29 pm
 Post subject: Hi Lo's
PostPosted: Tue Jun 10, 2008 11:30 am
I have a standard mini with cooper s flares that I want to buy 12 inch rims for.
I already have the tyres which are 70 series 165 wide(Dunlops bought for $50 each) and have been told that the front tyres will not rub but the rear tyres will.
Just wanted to know that if I had 12inch tyres replacing standard 10 inch tyres without suspension modification and the tyres were 70 series will using hi -los, and jacking it up, will this solve the problem.
Thanks
PostPosted: Wed Jun 11, 2008 8:25 pm
No. The problem is the length of the rear trailing arm - not the height.
Cheers, Ian
PostPosted: Wed Jun 11, 2008 8:40 pm
UK and Oz Minis that had 12" wheels came with 145/70-12 rubber so they would miss. :wink:
PostPosted: Wed Jun 11, 2008 9:04 pm
165/70-12s are very high in the side wall, I think Josh (Mini Mad) had a drama with this size tyre on his Mini.
Cheers Pete
PostPosted: Wed Jun 11, 2008 10:08 pm
Cheers Pete
Yes Josh bought some 165/70-12 A008s real cheap, we used Mr Anglegrinder so they would turn.. just!! :lol:
They were fouling the outer bracket, not the arm- but it depends on what wheels you have.
