It is currently Sat Jul 19, 2025 3:02 pm
 Post subject: Pedal Strength
PostPosted: Wed Jun 11, 2008 9:34 am
I'm pulling apart and re-assembling a pedal box.
Basically, I'm using the frame bit from a late model car with the pedals from an early one.
The key difference between pedals is the thickness of the steel they are made from.
I can't remember exactly, but the later pedals appear to be 6mm, the early ones are 4mm, with a rib welded down the side.
I've had to grind about 3mm or so off the top of the ribs to get the pedals to clear the brake switch.
The question now on my mind is, is it safe to use the early pedals in my setup?
Clutch is no issue, but the brakes are unboosted single circuit.
Anyone ever bend or snap a brake pedal?
Thanks.
PostPosted: Wed Jun 11, 2008 10:14 am
i bent a standard early pedal at hay (clutch)
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed Jun 11, 2008 7:09 pm
Got a pic?
I sort of know where it'd fail, but still would like to see.
PostPosted: Wed Jun 11, 2008 7:14 pm
I've never known of a b-r-a-k-e pedal to BREAK, and I've been racing an early setup without a booster for over 20 years. :shock:
Curly
