It is currently Sat Jul 19, 2025 3:05 pm
 Post subject: Hydro Pipes
PostPosted: Tue Jun 10, 2008 4:58 pm
I've just taken the hydro pipes down to have a look at their state and naturally enough they are rusted to hell...
Were the pipes anything special? They look to be aluminised steel pipe to lessen exterior corrosion. Can anyone recommend a source for pipe that would be up to the task?
Mick
PostPosted: Tue Jun 10, 2008 5:33 pm
i know the hydro pipes are a larger diameter is it the same material as brake lines try and get a larger size
PostPosted: Tue Jun 10, 2008 5:35 pm
They are very light gauge really...I was thinking the same, but brake pipe doesn't come that big and hydraulic pipe might be too heavy a gauge....?
PostPosted: Tue Jun 10, 2008 5:36 pm
alsminik wrote:
i know the hydro pipes are a larger diameter is it the same material as break lines try and get a larger size
Morris1100 where are you?
Or even SGC???
PostPosted: Tue Jun 10, 2008 5:51 pm
Pirtek can make new ones if you give them the old ones as samples.
Minispares sell new ones, & also sell a replacement nylon tubing set.
PostPosted: Tue Jun 10, 2008 5:52 pm
You can get bundy tube big enough. I thought it was for the likes of truck brake lines.
:D
PostPosted: Tue Jun 10, 2008 6:21 pm
Ah ok, I reckon I will ask. I've got a pipe flarer around here somewhere, I'll see if I can get the straight tube from a brake joint and put the old fittings on once I've bent it up.
PostPosted: Tue Jun 10, 2008 6:59 pm
I think it is steel bundy tube.
Try a brake place but it would need to be a good one.
Some blokes overseas are using a nylon/plastic one. :shock: It will work as long as it is a high enough rated pressure.
PostPosted: Tue Jun 10, 2008 7:39 pm
I believe it is just steel hydraulic line, same as used in industrial hydraulics.
Talk to Pirtek or Enzed... :wink:
PostPosted: Tue Jun 10, 2008 11:05 pm
I reckon I'll use that stuff on my traveller when I put hydro in it.... I used some 4mm pneumatic line and quickconnect connectors for my latest hydro pump effort (I was in a hurry at 1am!)
PostPosted: Wed Jun 11, 2008 5:10 pm
Just make sure you go high enough with the pressure. They run on about 310psi static but on full bump it will go way higher.
PostPosted: Wed Jun 11, 2008 5:56 pm
I raided the local Enzed today, they unfortunately didn't stock it (only the really high pressure stuff which I would have thought would be fine, except for the high cost and difficulty in bending). They did point me directly to the local ABS franchise who were able to provide the correct tube for 13 dollars a meter.
They didn't have enough there today, so I will go back on Thursday to pick it up..
Now to get a double flairing tool and some spare time .....
